Fuel Pump Excentric
Fuel Pump Excentric Empty Fuel Pump Excentric
Post  JR Performance Motorsport July 25th 2011, 6:47 pm
My new cams have 7/16" bolts instead of 3/8". What do you use to drill them larger, I have killed 3 drill bits so far ?
Jim
http://www.e-PerformanceMarine.com
Fuel Pump Excentric Empty Re: Fuel Pump Excentric
Post  Lem Evans July 25th 2011, 6:53 pm
Edit: I've seen you need to drill the eccentric........not the cam. You may need to use a machine tool on a Bridgeport style mill.
Post  dfree383 July 26th 2011, 7:22 am
What Lem said, the parts are to hard for a regular drill bit.
Post  rmcomprandy July 26th 2011, 9:00 am
JR Performance Motorsport wrote:My new cams have 7/16" bolts instead of 3/8". What do you use to drill them larger, I have killed 3 drill bits so far ?
Jim
Use an eccentric from an FE engine which already has a 7/16" hole.
Post  Lem Evans July 26th 2011, 9:07 am
And, FRPP sells one with a 7/16" hole.
