What's your timing ?
+8
stanggt
TRUKPULR
jason
12 posters
What's your timing ? Empty What's your timing ?
Post  jason July 29th 2011, 8:45 pm
I'm running 37* N/A a few ford guys I know say big fords like timing , my small block was 34*. what are you guys running?
jason
jason
What's your timing ? Empty Re: What's your timing ?
Post  rmcomprandy July 29th 2011, 8:53 pm
jason wrote:I'm running 37* N/A a few ford guys I know say big fords like timing , my small block was 34*. what are you guys running?
Which cylinder heads at what compression ratio ... ?
Post  jason July 29th 2011, 9:25 pm
Edelbrock rpm's with 12.5-1 the heads flow 370 at .700 on a 572
jason
jason
Post  TRUKPULR July 29th 2011, 10:16 pm
My A-head deal likes 34 Dreg. or 36 Dreg.
Dan
TRUKPULR
TRUKPULR
http://www.shazampulling.com
Post  IDT-572 July 29th 2011, 10:46 pm
We found that 35-36 ran the best at the track @12:1 compression3000 lb car
Post  IDT-572 July 29th 2011, 10:47 pm
Post  jason July 29th 2011, 11:35 pm
I know you guys are thinking why edelbrocks , well I was just gonna do a 460 so i bought the heads first and was stuck with them , but it made 800 hp and 758 on torque . I don't know what heads to get to wake it up. I'm planning on heads cam pistons and intake in a year or two
jason
jason
Post  cool40 July 30th 2011, 12:22 am
my A-head 526 on alky likes anywhere from 24-34lol.better air i've ran it low and picked up some.tonight in bad air with a gear change i found it to like 32 better but it was also a little fat cuz the air sucked. Very Happy
Post  bbf-falcon July 30th 2011, 7:33 am
On a deal like yours,I would say 34 thru 38*. starting at 36 and go from there. If you are going w/new pistons and want to stay w/your headers I would go w/p51's but the A heads would be a better choice if the cubes are over 572. jmo
Post  stanggt July 30th 2011, 10:13 am
Cliff from Jon Kaase racing told me to run 28-29* with my scj heads, said they picked up 50hp on dyno when they droped timing down when they were testing with these heads
stanggt
stanggt
Post  rmcomprandy July 30th 2011, 11:46 am
Every cylinder head type and chamber shape, (which also includes the top of the piston in that), will require a different amount of ignition advance to be at its optimum.
28 to 31 degrees usually IS correct for an SCJ, a little less for a P-51 but, not an Edelbrock. I have encountered some low compression Edelbrock headed engines which need 39 or 40 degrees.
I haven't had experience with high compression Edelbrock headed engines but, it would seem that 35 to 38 wouldn't be out of the question with gasoline.
Post  bruno July 30th 2011, 12:43 pm
32 n/a for my rpm edlebrocks 13.5-1
http://WWW.CKRME.COM
Post  jason July 30th 2011, 4:24 pm
I built the headers I have now and I don't have problem doing it for a set of A-heads , is the bore center on an A-460 block with a 4.5 bore gonna work with those heads?
jason
jason
Post  res0rli9 July 30th 2011, 5:16 pm
[quote="jason"]I built the headers I have now and I don't have problem doing it for a set of A-heads , is the bore center on an A-460 block with a 4.5 bore gonna work with those heads?[/quote
YEP!
Post  rmcomprandy July 30th 2011, 5:54 pm
[quote="res0rli9"]
jason wrote:I built the headers I have now and I don't have problem doing it for a set of A-heads , is the bore center on an A-460 block with a 4.5 bore gonna work with those heads?[/quote
YEP!
The block bore spacing is the same ... the exhaust port spacing on TFS A460 heads are not the same.
They are on 4.840" spacing, (not 4.900" spacing), so an out of the box Big Block Chevy header flange will have correct port alignment. The exhaust bolt pattern on all A460 heads is Big Block Chevy per tube however, the early Ford Motorsport A460 heads had them spread slightly on Ford 4.900" spacing.
Post  jason July 30th 2011, 6:42 pm
[quote="rmcomprandy"]
YEP!
so I could probably cut the flange off my headers and spread them to fit those heads?
jason
jason
Post  Lem Evans July 30th 2011, 7:01 pm
Tube size or did I miss it?
Post  jason July 30th 2011, 7:20 pm
Lem Evans wrote:Tube size or did I miss it?
Tube size is 2"
jason
jason
Post  Lem Evans July 30th 2011, 7:31 pm
With a big BBF I'd think about 2-1/4" primary or bigger. J.M.O.
Post  Nevs July 30th 2011, 8:10 pm
Tube size is 2"
I'm with Lem, 2" is too small on an A460 application. 2 1/4", would be my choice unless it's a real rock n'roll set of heads, then I'd go 2 3/8ths...
Post  jason July 30th 2011, 8:41 pm
Nevs wrote:
Tube size is 2"
well that sucks! Oh well it's not like I'm busy or anything , why not build another set of headers . Do they have to be 2 1/4 all the way ? What size collector ?
jason
jason
Post  Nevs July 30th 2011, 9:42 pm
We went 2 1/4" into a 4" collector. We built ours out of a Hedman kit with a bunch of additional j bends.
Post  jason July 30th 2011, 10:02 pm
Nevs wrote:We went 2 1/4" into a 4" collector. We built ours out of a Hedman kit with a bunch of additional j bends.
I'll buy some j bends then , I made the ones I have now 29" + or - an inch , I can't remember why or who told me to make them that long but I think they didn't hurt the power . How long should I make these for A-heads ?
jason
jason
What's your timing ? Empty Timing
Post  manofmerc August 1st 2011, 7:14 pm
I run 36 total with my edelbrocks It will slow down if I put it up to 40 total .11.67 to 1 compression 18 initial and 18 in the dist. 466 cu.in cyclops
manofmerc
Post  IDT-572 August 2nd 2011, 9:00 am
manofmerc wrote:I run 36 total with my edelbrocks It will slow down if I put it up to 40 total .11.67 to 1 compression 18 initial and 18 in the dist. 466 cu.in cyclops
x2 this is what we found with a flat top 472 un ported Edelbrocks
