tranny mount
Travis460
tranny mount
you guys runnin fox's with big blocks and c6 did you have to fab up a tranny mount? or is there something i can buy from the parts store.
thanks
Travis
thanks
Travis
Travis460- Posts : 17
Re: tranny mount
I've just fabbed up my own in the past, not on that combo but others.
Re: tranny mount
You talking about the rubber trans mount or the crossmember. You should be able to cut the spot welds and slide the crossmember back to get the trans mount to line up.
jbozzelle- Posts : 3705
Re: tranny mount
You said tranny mount and that u can get at the parts store.
nuclearcobra- BBF CONTRIBUTOR
Re: tranny mount
I guess it depends on what engine was originally in your fox. If it was a 5.0 with the "double hump" x-member, all you have to do is cut the spot welds loose on the x-member and slide it all the way to the rear and reweld it. If it is single hump style, you'll probably have to find a v8 one or buy the FRPP xmember that comes unwelded for use with swaps. As far as the mount goes, the stock 5.0 mount will work or you can buy the Energy Suspension urethane mount like I did. Your "location" is listed as West Branch, is that West Branch Michigan?
Gary
Gary
GTmustang- BBF CONTRIBUTOR
Re: tranny mount
I made a new one and moved it back. when I did it also give me more room for exaust.
stanggt- Posts : 494
» tranny mount
» Tranny mount question
» Poly or rubber tranny mount with motor plates?
» good news not Lookin fer a C6
» Lentech AOD tranny
