eliminator block
Wayne Pearce
fatal addiction
eliminator block Empty eliminator block
Post  fatal addiction August 5th 2011, 5:39 pm
is their any casting #'s to tell if it's an ultra or a premier? thanks eric
fatal addiction
fatal addiction
eliminator block Empty Re: eliminator block
Post  Wayne Pearce August 5th 2011, 5:50 pm
I can't say about casting numbers, but the premier block has billet steel main caps, and the ultra has cast iron caps. If you can see the engine, telling the caps apart shouldn't be too hard. I hope that was helpful.
Wayne (SAWDOFF) Pearce
Wayne Pearce
Post  fatal addiction August 5th 2011, 5:55 pm
Wayne Pearce wrote:I can't say about casting numbers, but the premier block has billet steel main caps, and the ultra has cast iron caps. If you can see the engine, telling the caps apart shouldn't be too hard. I hope that was helpful.
thanks but i can't see the block and the guy is telling me it has steel caps?? but i just thought if it had #'s casted on it i could find out that way before i go look at it. thanks eric
fatal addiction
fatal addiction
Post  cool40 August 5th 2011, 9:27 pm
i dont know if they'll tell you anything but mine is an ultra and has #on the left front bank>>>eliminator block 605_0010
Post  cool40 August 5th 2011, 9:28 pm
^kinda hard to see in that pic but its at the top of the bore
Post  DanH August 5th 2011, 11:16 pm
premier also has A1 tech studs and 12 point nuts on all 5 caps , except outers , got bolts
DanH
Post  cool40 August 5th 2011, 11:30 pm
i dont know what your plans are but the caps are all i see from one to the other. http://www.eliminatorproducts.com/product/7.aspxr. FAIL!
Post  fatal addiction August 6th 2011, 5:49 am
This block is brand new and looks like it has been powder coated on out side and inside where timing chain goes? I will see what kind of bolts it has that mite be the easiest way to tell. Thanks guys I appreciate it. Im building a 700" nos Thor headed motor around 750 hp nos..thanks again
fatal addiction
fatal addiction
Post  bruno August 6th 2011, 10:20 am
fatal addiction wrote:This block is brand new and looks like it has been powder coated on out side and inside where timing chain goes? I will see what kind of bolts it has that mite be the easiest way to tell. Thanks guys I appreciate it. Im building a 700" nos Thor headed motor around 750 hp nos..thanks again
wow , im gonna watch this build closely ....... she will be hosed Twisted Evil
http://WWW.CKRME.COM
eliminator block Empty Premier vs. Ultra
Post  IDTJay August 8th 2011, 8:30 am
The block in the picture is an Ultra block. The caps are cast nodular iron (Premier has billet steel) with the standard main bolts (not A1 studs / bolts) at all locations. The block castings are the same between the Premier and Ultra before they are machined. The Ultra block was designed to be a lower cost block (cast caps vs. billet caps). The cast caps used in the Ultra block are the same as the Sportman block.
IDTJay
http://www.idtracing.com (soon to be launched)
