roller rockers?
stanggt
roller rockers?
what roller rockers work the best on the 6049 scj aluminum heads? My Milodons are not gunna cut it. Thanks
Chris
Chris
stanggt- Posts : 494
Re: roller rockers?
give Lem Evans or Randy Malik a call on mon. and they can get you the right pieces
Re: roller rockers?
crower
Re: roller rockers?
ok, talked with Jon Kaase today and he told me to use harland sharp , he said they had the rocker arm for these heads. Called Harland Sharp and they have a head specific arm for these heads, HS#S4073 for $334.95 Anyone use these on scj heads?
Re: roller rockers?
Harland Sharp is the only stud rocker that I have ran with zero failures.
I wish they made a shaft rocker
Curt- Posts : 2791
Re: roller rockers?
Curt wrote:Harland Sharp is the only stud rocker that I have ran with zero failures.
You have started already, want me to send you some green oil?
342g- BBF CONTRIBUTOR
Re: roller rockers?
Hey, if I run low on VR, I am not opposed to running green oil. LOL
That will keep those Harland Sharp rockers very happy!
Curt- Posts : 2791
Re: roller rockers?
are you running the s4073 on scj heads yourself?
Re: roller rockers?
No, I think everything I have ran was the 4005?. Kaase might have tweeked something for the better with the newer part number.
If he suggested it, it must be right. After all, he designed the head.
Curt- Posts : 2791
Re: roller rockers?
stanggt wrote:ok, talked with Jon Kaase today and he told me to use harland sharp , he said they had the rocker arm for these heads. Called Harland Sharp and they have a head specific arm for these heads, HS#S4073 for $334.95 Anyone use these on scj heads?
YES ... those are the rockers we helped get specially designed for the intakes on SCJ heads; (with the correct length pushrod, they work fine on the exhaust side, too) ... they are slightly different than the S4005 rockers that Harland Sharp normally lists for the big block Ford.
Personally, I get one set of each and use the S4073's on the intake and the S4005's on the exhausts when there is more than one engine to build using those heads.
Re: roller rockers?
Curt wrote:No, I think everything I have ran was the 4005?. Kaase might have tweeked something for the better with the newer part number.
cool thanks for info, just talked with a local shop and they can get me these rocker arms for $300, looks like a good deal to me and solve some of my issues.
Re: roller rockers?
thanks for all input, getting closer to rapping this thing up just need to get pushrods figured out now.
» Roller rockers
» *SOLD* 632 All-Aluminum Engine - C460 Heads, RDI Motorsport Block, CFE Intake, 3 Nitrous Kits
» Roller Rockers
» Which Roller Rockers ?
» Roller Rockers
» Roller Rockers
» Roller Rockers
