Gringing noise 04 F350????
David Willingham
scottke
Gringing noise 04 F350???? Empty Gringing noise 04 F350????
Post  scottke Tue 9 Aug 2011 - 21:52
Need some input from you tech guys. When I'm turning left at much speed I get a kind of grinding noise. I have jacked it up and there seems to be no play in the wheel bearing. The rotor surface is smooth on both sides. A few times when i have pulled into a parking spot with the wheels turned slightly left, I have gotten a slight vibration you can feel in the floor at idle. Other times it doesn't vibrate at all.????????
It's really starting to get on my nerves! Mad
Just thought I'd see if anyone had a few Ideas on anything else I could look at before I take it to someone to look at. pale
Thanks in advance.
scottke
scottke
Gringing noise 04 F350???? Empty Re: Gringing noise 04 F350????
Post  bbf-falcon Tue 9 Aug 2011 - 22:23
Knuckle joints in the axle confused
Post  scottke Tue 9 Aug 2011 - 22:39
possible Crying or Very sad
scottke
scottke
Post  69F100 Tue 9 Aug 2011 - 22:59
could be clucthes or spider gears in the 3rd member trying to lockup
Post  David Willingham Wed 10 Aug 2011 - 11:20
The wheel hub will make a grinding noise, but not for long.... Mad Been there done that. Now there is a grinding sound on mine when you turn and it's the clutches in the rear diff. I'm going to try new fluid and friction modifier and see if that stops it.
David Willingham
David Willingham
Post  jbozzelle Wed 10 Aug 2011 - 12:19
4x4?
My 2008 has a sort of small "hop" to it when turning left with the wheel at full lock and turning slow. I think it's ball joints. I plan to drop it off later this week to get it looked at.
Post  richter69 Wed 10 Aug 2011 - 13:20
rear diff clutches can do what you guys describe.
Post  Barney Wed 10 Aug 2011 - 13:58
My Excursion started doing that about a week before the left hub went bad.
Barney
Barney
Post  whitefield Wed 10 Aug 2011 - 14:01
Barney wrote:My Excursion started doing that about a week before the left hub went bad.
X2 My old 2000 f250 did the same thing!
whitefield
whitefield
Post  bbf-falcon Wed 10 Aug 2011 - 16:13
Alot of the Ford 4wd trucks in the 90's do the hopping deal when you cut it sharply to the left . I just figured it was normal. scratch
Post  richter69 Wed 10 Aug 2011 - 16:39
bbf-falcon wrote:Alot of the Ford 4wd trucks in the 90's do the hopping deal when you cut it sharply to the left . I just figured it was normal. scratch
normal for a f'd up clutch pack in the rear diff...............
Post  bbf-falcon Wed 10 Aug 2011 - 20:32
Open rear ends don't have clutch packs .............DA
Post  richter69 Wed 10 Aug 2011 - 21:29
who's talkin about open diff's?........... DF
Post  richter69 Wed 10 Aug 2011 - 21:50
The more I read this, does the truck have an aftermarket downpipe? 6.0?
..and if it does have then check the clearance between the downpipe and the floorboard, even if it looks to have some room you get it in a bind the chassis flex will let the downpipe contact the floorboard. You can loosen the clamp at the turbo, have someone pry the exhaust system over toward the engine and re tighten the clamp. Seen it happen many a time with the big aftermarket downpipes.
Post  scottke Fri 12 Aug 2011 - 20:56
I just put a total 4" MBRP exhuast on it a month ago!!!! I'll look at it. Thanks
scottke
scottke
Post  richter69 Fri 12 Aug 2011 - 22:12
Wink
Post  scottke Fri 12 Aug 2011 - 22:29
richter69 wrote: Wink
Man, I owe you big time! Just got done readjusting all the exhaust. Took care of it! Very Happy Very Happy Very Happy Very Happy
THANKS!
scottke
scottke
Post  richter69 Fri 12 Aug 2011 - 22:54
THANKS!
no problem man.............. Cool
