OK, I NEED some pushrods!!!
+6
quick 52
Wayne Pearce
KY JELLY
stanggt
10 posters
Here our the #'s I got for pushrod lengths on my scj heads with HS S-4073 rockers, IN/8.915 and EX/9.120 so I need something close to that, what is available and who has them. I need asap
stanggt- Posts : 494
Re: OK, I NEED some pushrods!!!
Where did you get those lenghts?
Curt- Posts : 2791
Lem Evans @ bf evans raceparts can fix you with a set of trend pushrods
KY JELLY- Posts : 1530
Trend push rods = good stuff!!
Wayne (SAWDOFF) Pearce
Wayne Pearce- Posts : 658
stanggt wrote:Here our the #'s I got for pushrod lengths on my scj heads with HS S-4073 rockers, IN/8.915 and EX/9.120 so I need something close to that, what is available and who has them. I need asap
In the past, those numbers would be good at zero lash or a slight preload as with a hydraulic lifter.
They are usually a bit shorter when lash is introduced so, be aware.
Off the shelf pushrods are usually sold in .050" length differences. I can get you any size you want from Trend; off the shelf is today but, customs are a week or more to get done.
on the head with .026 lash installed. Jon Kaase told me to set the flat part of rocker parralel to retainer and take measurement as well as ck how the roller tip contacts valve. So that is what I got with this camshaft profile and adjustable pushrod checker. At half lift the pushrod is square to rocker.Curt wrote:Where did you get those lenghts?
rmcomprandy wrote:stanggt wrote:Here our the #'s I got for pushrod lengths on my scj heads with HS S-4073 rockers, IN/8.915 and EX/9.120 so I need something close to that, what is available and who has them. I need asap
Ok, I will double ck and see if I can go with an 8.900/ and 9.100
u can google OE push rod in mt. clemens mi. they will have your push rod or can make them. price is good too they are a manufacturer of push rods for lots company and are used by many engine builders.
quick 52- Posts : 612
what dia. do I need, 3/8 or 5/16 pushrods? SCJ heads Im thinking 3/8
X2Wayne Pearce wrote:Trend push rods = good stuff!!
Tip...... You should to order them thru someone who knows what to get. Pushrods aren't just pushrods, you need to know what materials, thickness, tips, oil holes, ect to order.
stanggt wrote:what dia. do I need, 3/8 or 5/16 pushrods? SCJ heads Im thinking 3/8
Yes get the 3/8 but make sure you have 3/8 guide plates on the heads
Lem Evans wrote:Trend has pushrods in .025" increments.
In most common sizes however, not "off the shelf" with all sizes.
