timing cover seal
timing cover seal
when ur installing it does the open side of the seal go in the cover first or the solid side ? im having a brain fart
nuclearcobra- BBF CONTRIBUTOR
Re: timing cover seal
so when your looking at the inside of the cover you see the solid side of the seal (ie when your tapping it in your tapping on the solid side of the seal) right ?
NO! solid side of the seal face the out side of the engine.
res0rli9- BBF CONTRIBUTOR
Thanks guys just wanted to make sure thats the same way they go in for a early 302/351w, after looking at it if i did put it in backwards it looks like you would knock the spring loose pushing the spacer through it.
