bbf engine swap fox body
GTmustang
zbob
83-88T-Bird Guy
mpinder18
bbf engine swap fox body Empty bbf engine swap fox body
Post  mpinder18 September 18th 2011, 8:49 am
I have a bbf engine swap kit 79-93(headers, motor mounts, oil pan) from Summit. I'm a installing a 502 bbf, C6 in 89 m-tang. What else do I need? I understand it might hit the stock power brake booster.
mpinder18
mpinder18
bbf engine swap fox body Empty Re: bbf engine swap fox body
Post  83-88T-Bird Guy September 18th 2011, 1:59 pm
mpinder18 wrote:I have a bbf engine swap kit 79-93(headers, motor mounts, oil pan) from Summit. I'm a installing a 502 bbf, C6 in 89 m-tang. What else do I need? I understand it might hit the stock power brake booster.
Welcome to the forum.
If you use the tall Motorsport valve covers, then you will need to convert to manual brakes.
If you use the short (stock height) valve covers, you can keep the small p/brake booster. It will clear, but is tight.
Not sure if your '89 is a factory 5.0 car or not, but if it was, then it came from the factory with the small diameter booster. if it was a V-6 car, then you will need to change or get rid of the booster.
Your double hump trans crossmember (if it was a factory 5.0 car) will work fine with the C-6. You can even re-use the AOD/T-5 trans mount.
If you are using the Hooker 6224 swap headers, then the # 7 header tube will need to be modified to clear the steering shaft.
Hope this helps.
83-88T-Bird Guy
83-88T-Bird Guy
Post  zbob September 18th 2011, 10:47 pm
kmember spacers gave me more room for the shorty header exit clearance at the bottom of the firewall. they also allowed me enough room for a twin diaphragm booster (84ish). it did make steering shaft clearance troublesome though. i used a flaming river shaft with their rack. had too reef the column over to the side. bobn
zbob
Post  GTmustang October 1st 2011, 7:22 pm
A BIG hammer for clearancing the trans tunnel for the C-6! Just dump the brake booster and go with a manual brake adapter kit. If you run anywhere nnear a big cam, the power brakes won't be dependable anyway. Stops just fine with the manual brakes. If you want to keep the booster, it will fit with stock style valve covers but will be a pita to get the drivers side valve cover off to adjust valves.
Gary
GTmustang
Post  zbob October 2nd 2011, 9:58 pm
fwiw i did not have to hammer the tunnel at all. i am spoiled, i did not like the manual brake capabilities at all. not to be contrary just pointing out my experiences....i do note that my car is a low 12sec ride though....bobn
zbob
Post  BOSS 429 October 2nd 2011, 10:45 pm
BOB .... IT JUST MAKES IT EASIER TO REMOVE JUST THE TRANS IF YOU CLEARANCE THE TOP AERA OF THE TUNNEL,PLUS YOU REALLY NEED TO IF YOU USE A SHEILD,
LOOSE THE POWER BRAKE STUFF YOU DONT NEED IT ANYWAY,AND YOU ENG MIGHT NOT MAKE ENOUGHT VAC FOR IT
Post  BigBlockRanger October 3rd 2011, 4:27 pm
I put k-member spacers in mine. I lengthened the stock steering shaft a bit to clear the headers better. I am running power brakes and notched the valve cover to clear it. The back vc bolt is a pain to get to.
Spacers allowed me to get it all under a stock '83 hood.
bbf engine swap fox body 148576_460236669484_687514484_5356974_7684383_n
Post  bruno October 3rd 2011, 9:03 pm
you did a great job on the v/c notching
http://WWW.CKRME.COM
Post  BigBlockRanger October 4th 2011, 10:58 am
Thanks! And it still clears my Jomar stud girdle! Smile
Post  lghting94 October 4th 2011, 12:29 pm
Bigblockranger how thick were the k-member spacers you used?
lghting94
lghting94
Post  83-88T-Bird Guy October 4th 2011, 2:41 pm
BBR is hard core about his power brakes ! ....LOL
Man, that's sweet work on the notched cover.
I had to use 1 1/2 inch k-frame spacers to get the 460 in my 91 Coupe to clear the stock hood. (with a Torker II intake of course)
bbf engine swap fox body PicsNov142010005
83-88T-Bird Guy
83-88T-Bird Guy
Post  BigBlockRanger October 4th 2011, 2:54 pm
I used 1-1/2" square steel tubing for my spacers. The vc notch looks better now that it's finished!
bbf engine swap fox body A2hqo
With a 2-1/2" filter and a drop base it fits nice under my stock '83 hood and scoop.
bbf engine swap fox body 34ys45y
Post  83-88T-Bird Guy October 4th 2011, 3:11 pm
What intake are you using ? Did you cut a hole under the factory scoop ?
83-88T-Bird Guy
83-88T-Bird Guy
Post  BigBlockRanger October 4th 2011, 5:16 pm
FRPP single plane (Victor)
bbf engine swap fox body 301573_10150337529604485_687514484_7930186_62728507_n
Factory hood already had a hole, but I needed to trim it just a bit to clear the air filter along the back.
bbf engine swap fox body 76507_462794219484_687514484_5388509_7845293_n
Post  D-Rail October 4th 2011, 5:57 pm
If you use tall valve covers to clear roller rockers there is clearance issues. I got a hydroboost unit from the local pick-&-pull
Mark VIII I think Lines from a cobra at autozone. Now I stop as good as I go!!
D-Rail
Post  lghting94 October 5th 2011, 10:00 am
Thank you Allen and BigBlockRanger
lghting94
lghting94
bbf engine swap fox body Empty Thanks for all the help
Post  mpinder18 October 5th 2011, 11:45 am
Hey guys thanks, I'm serving in Afghanistan, soon to be home. My motor was finished a week ago (502 bbf) in the states. I recently bought( (also last week) a 84 fox, 12 pt caged, tubbed, ladder bar, 9 inch (no center section), manual rack, k-membered with motor plates for bbf. I was going to use my 89 347 hatchbatch car as a conversion, but now I will use the 84. I like the pictures about the brake booster, had heard that there could be issues with that or the steering shaft.
mpinder18
mpinder18
