what timing lights do you guys like?
+17
Hangman
'65 T-BOLT
BigDave65
Larry Williams
racnrick
bigblockfox468
mitch
21 posters
I need to buy a new timing light and would like some recomendations.
mitch- Posts : 116
Re: what timing lights do you guys like?
MSD light is what I have now. you can see the timing marks even in bright day light.
mitch wrote:I need to buy a new timing light and would like some recomendations.
One wire, internal battery powered Snap-On ... you'll use it a lot more because it's SOooooo easy.
i have a digital mac and a snap on .... and they are all off ...the msd works the best
I picked up on of these a couple of years ago on ebay. It works great. Brighter than a couple of newer ones I have.
Read the article. Good info.
http://www.dragracingonline.com/technical/vii_10-lights-1.html
David Cole wrote:I picked up on of these a couple of years ago on ebay. It works great. Brighter than a couple of newer ones I have.
Yep thats the one I got
old cheap chrome craftsman here..................best light I ever had, had it like 20 years lol.
bruno wrote:i have a digital mac and a snap on .... and they are all off ...the msd works the best
The Snap-On that I have has been checked numerous times and is right-on however, it has NO dial adjust timing feature ... it shows what the timing IS, period.
Whatever is decided upon, use that SAME light every time not a few different ones.
I think I read somewhere, or heard it that the dial adjustable light will give an inaccurate reading with MSD ing. Anyone else heard that?
racnrick- Posts : 462
MSD for me
Larry Williams- Posts : 884
richter69 wrote:old cheap chrome craftsman here..................best light I ever had, had it like 20 years lol.
Same here, had it forever seems like.
BigDave65- Posts : 567
mine is retired, I have been using a Snap-On non digital with the dial.BigDave65 wrote:richter69 wrote:old cheap chrome craftsman here..................best light I ever had, had it like 20 years lol.
'65 T-BOLT- Posts : 1464
same here. had an MSD and Snap-on before and they were both exactly 6 degrees off.
whatbumper- Posts : 3024
I have the Chrome Actron from Advance Auto looks just like Rick's craftman I think I payed around 60 BUCKS FOR IT AND WORKS GREAD ON MSD
whatbumper wrote:richter69 wrote:old cheap chrome craftsman here..................best light I ever had, had it like 20 years lol.
WE TESTED A bunch of lights a few years ago and found it wasnt the light fault , it was the plug wires, some are so thick some lights picked up better then others, test this by useing a cheap wire sometime over a thick wire, we started carrying a stock wire just to check timing on a few diff engines.
i have a 20.00 sears,and a 400.00 snapon, both always read the same,one a dial,other a dit.
-rich
and yes always use the same light on the same engine
BOSS 429- Posts : 2372
whats the # on the old chrome craftsman timing light, think I have that one.
Mine is # 2134
Mine is # 2134
res0rli9- BBF CONTRIBUTOR
res0rli9 wrote:whats the # on the old chrome craftsman timing light, think I have that one.
Mine is # 2134
That's the number they list in the article. Same one I use. Also have an older Craftsman one that you have to slip a wire under the ign. wire on the dizzy. Get zapped too many times by that one when turning the dizzy.
Hangman- Posts : 32
racnrick wrote:I think I read somewhere, or heard it that the dial adjustable light will give an inaccurate reading with MSD ing. Anyone else heard that?
Yep
I have an old Mac tools one and it always works. I have never tested it against anything else though so I don't know if it is off or not. Interesting article and thread.
jasonf- BBF CONTRIBUTOR
old chrome Craftmans Non dial back light
fast89gt- Posts : 8
Actron Digital from Autozone. $99.00
I also have the Craftsman chrome adjustable type but I wasn't sure if it was accurate so I replaced it.
I drop it too much because I forget about the detachable cord.
The Actron does rpms and the digital readout is helpful.
jmf32- Posts : 48
» MSD Timing Lights
» Timing lights...It Used to Be....
» Advance Cam or Not ?
» Timing Pointer for Stock Timing Cover
» engine timing and nitrous timing
