firewall for hatchback stang???
firewall for hatchback stang??? Empty firewall for hatchback stang???
Post  stanggt September 20th 2011, 9:08 pm
how do you guys who run mustang hatchbacks protect yourself from the fuel cell and pass tech. My car has a cell dropped thru and flush mounted in floor and the fuel filler neck comes out behind license plate so you can fill without lifting hatch. the cell seams to be enclosed in a steal shell. Doesnt that filler neck need to be enclosed somehow or what? battery is now in an enclosed sealed batterybox and vented thru floor so I should be good there. Any thoughts?
stanggt
stanggt
firewall for hatchback stang??? Empty Re: firewall for hatchback stang???
Post  bruno September 20th 2011, 11:00 pm
wolfe makes one
http://www.wolferacecraft.com/detail.aspx?ID=295
http://WWW.CKRME.COM
Post  DILLIGASDAVE September 21st 2011, 2:53 am
I guess since basically the rules want the driver completely separated from any part of the fuel system that if the filler neck tube was exposed/out in the oped in the trunk it could be a problem. But the question here is does something as small as a filler neck really call for a full width bulkhead between the wheel tubs. Or would just covering the neck it's self with a little sheet aluminum be enough to pass tech.
If it was a race-only car with a decent sized cell I wouldn't place the cell under the floor anyway, takes up too much present/future wheelie bar room under the car. In that situation I would have put the cell in the trunk & used a bulkhead. A street driven car on the other hand could go either way, in or under the trunk floor as more room under the rear of the car could be less of a concern.
Post  stanggt September 21st 2011, 10:04 am
bruno wrote:wolfe makes one
I could make one of those, my back bars would have to go through that anyways, does the nos bottle have to be seperated from driver also? thanks
stanggt
stanggt
Post  bruno September 21st 2011, 10:08 am
no, just have the proper blow off disc and vent the bottle outside the car
Post  stanggt September 22nd 2011, 12:39 pm
Ok, thanks for info Bruno
stanggt
stanggt
Post  nuclearcobra February 5th 2012, 10:46 am
This is legal, the cell is underneath with a door to get to the filler cap. firewall for hatchback stang??? Th_stangtires004
nuclearcobra
nuclearcobra
Post  stanggt February 7th 2012, 3:43 pm
here is what I am working with. Think I can just sheild the neck area to the back of the car and be good.firewall for hatchback stang??? Partstosell042
stanggt
stanggt
Post  DILLIGASDAVE February 7th 2012, 10:53 pm
stanggt wrote:here is what I am working with. Think I can just sheild the neck area to the back of the car and be good.
If the steel braided line in the pic is a tank vent or return line, it also needs to be separated from the driver & behind/under a firewall/floor since it is part of the fuel system.
Post  stanggt February 8th 2012, 10:25 am
Ya, I will probly just build a regular firewall for it and get it over with. Thanks for info
stanggt
stanggt
