stock efi vs carb and intake
gonna do some work on my 97 f350 4x4 crew cab
i use it to pull my trailer and daily driver
it has a 460 with 190,000 on it
still runs great
i was thinking about a cam kit upgrade
and possibly a chip
or another option is to do a cam
and intake and carb
gas milage is a concern but i dont get any better than my old
truck with a carb
i plan on a set of headers and cam for shure
not going for top hp but would like to pull my 36ft 5th wheel
with out beatin the crap out of it
i am also gonna eather rebuild the e4od that is in it or try to get away with new
shifting silonds
it is shifting funny and the od light flashes on and off but only dose it in the summer
kinda wierd but when it is cold out it works fine
still runs great
and possibly a chip
and intake and carb
truck with a carb
shifting silonds
jesse- Posts : 447
Re: stock efi vs carb and intake
i would think the efi would be the way to go for that application ......
I'd have to agree with Bruno.
dose any1 know what is a good upgrade for the stock efi
bigger injectors and throttle body?
i like the idea of useing the efi sonce it will be drivin daily in the winter
jesse- Posts : 447
shifting silonds
Could your trans problem be a warped valve body or maybe gasket leaking a little? Have a buddy with the same problem, when cold and fluid is thicker, or on the throttle hard, shifts fine. When warmed up good, has shifting problems (slow or hesitated shifting).
Hangman- Posts : 32
humm? could be
it dosent leak any fluid and warped valve body i guess it is possible
thanxs for the tip
i might buy a junk one from a slavage yard and switch out a few things befor i go for a rebuild
i might try to attempt a rebuild on my own i have now auto tranny knowalge
but i will buy a book and ask tons of questions on here lol
thanxs for the tip
jesse- Posts : 447
you have to be careful about what you do for mods with the EFI. It won't run right unless you can figure out how to get the computer custom tuned. I definately would not do bigger injectors with the stock computer.
mitch- Posts : 116
» weiand carb adapter 4500 carb flange to 4150 intake
» Tuning Demon Carb on Stock 460ci Pickup Engine
» stock 460 intake option
» What carb to use on stock 429 Torino
» if you had to run a stock intake manifold, what is the best casting to use other than the scj
