Silly Alt question
Silly Alt question
This will seem silly but since i'm not sure ... on a Alternator off my 1976 Thunderbird 460 , it has 3 wires.. 1 heavy wire to the battery, and 1 plug that has 2 wires.. Field and Stator...The Stator wire runs up to the electric choke. now the question is this.. The Field wire just connects up to the (run) position 12v hot right? just want to be sure I have it wired right... Thanks guys.
James1965- Posts : 21
Re: Silly Alt question
anyone?? 51 views and no one has an answer? guess I don't feel so bad about not knowing now.
alternator
What about the voltage regulator.....
557 mazda- Posts : 101
unless the Alt has been updated to an internal regulator it has to run through the regulator. Otherwise the Alt would charge at full rate all the time and smoke the battery.
plowboy34- Posts : 223
It should look something like this... and yes you would need a voltage regulator.
jasonf- BBF CONTRIBUTOR
Interesting. when i pulled this engine out of the 76 Thunderbird, there was no regulator. I'm not saying it wasnt missing, I'm just saying when i cut out the harness I did not see one.. thank you for the diagram , i'm going to go do some research on that car.
» Silly little gay mustangs
» 5.4 question
» Cam question?
» E85 question.....
» Eliminator premier block
» 5.4 question
» Cam question?
» E85 question.....
