Roll pin shearing
BigDave65
56Tbird
powerstrokeace
Roll pin shearing Empty Roll pin shearing
Post  powerstrokeace September 25th 2011, 9:52 am
Guy's been running the same combo since 2009 and for all the sudden the roll pin in the dist sheared back in june. the only changes made was a carb swap to E85. Well fast forward to Sept. A week a go we tested and had a few stumbles on the last two runs. So Saturday first pas the car wouldn't stall and labored down track. Guess what another roll pin sheared? What do you think?
Ace
powerstrokeace
powerstrokeace
Roll pin shearing Empty Re: Roll pin shearing
Post  Lem Evans September 25th 2011, 10:08 am
When you replaced the pin last time did you put the 1/8" back in it or did you go bigger?
Post  56Tbird September 25th 2011, 10:58 am
Double pin it. I had one do it years ago in my motorhome.It only had 35,000 miles on it.I broke 3 of them before I double pinned it. I think it was probably getting wore where it had spun on the shaft. I put another below it a half turn away and never had another problem.
56Tbird
56Tbird
Post  Lem Evans September 25th 2011, 11:04 am
The process we use over at Bass Boat Bob's........move the o.d. of the pin up to 5/32" and then drive a smaller pin into the i.d. of the 5/32" pin.
Post  G-Code September 25th 2011, 11:18 am
Increase od, make sure gear is press fit.
New engine builder will only use the mutli-layer roll pins, In the past I've used hardened roll pins I got from a lawn mower shop.
G-
Post  BigDave65 September 25th 2011, 11:37 am
I broke a pin a couple of years ago for the first time. I bought a bag of the mult-layer pins and have been just replacing it at the beginning of every season.
BigDave65
BigDave65
Post  cool40 September 25th 2011, 12:31 pm
Lem Evans wrote:The process we use over at Bass Boat Bob's........move the o.d. of the pin up to 5/32" and then drive a smaller pin into the i.d. of the 5/32" pin.
x3,never broke one.
Post  Curt September 25th 2011, 12:39 pm
This will fix it!
Roll pin shearing Newbuild12
Post  Lem Evans September 25th 2011, 1:06 pm
It sure will Smile
Post  cool40 September 25th 2011, 1:09 pm
Curt wrote:This will fix it!
that'd buy a lota roll pins Curt. pale
Post  Curt September 25th 2011, 1:15 pm
You've got a valid point there! Bob and Lem >>>>> Roll pin shearing SMILEYMONEY-1 Roll pin shearing 1sm376money
Post  Lem Evans September 25th 2011, 1:20 pm
Wait a minute there big boy.......Lem didn't recieve any $s for that pump.
Post  Curt September 25th 2011, 2:31 pm
Tru dat Lem, but you did get funding from a lot that the pump protects also shown in picture. king
Post  56Tbird September 25th 2011, 2:36 pm
Sure is alot of purty colors and fancy chit on there Curt!! Makes a Hillbilly feel all fuzzy and stuff Razz I like the double roll pin you mentioned there Lem Twisted Evil
56Tbird
56Tbird
Post  richter69 September 25th 2011, 3:48 pm
no broken pin worries here either...............external pump for the win.......... Basketball Basketball
Post  Lem Evans September 25th 2011, 5:31 pm
Curt wrote:Tru dat Lem, but you did get funding from a lot that the pump protects also shown in picture. king
Correct.....I was able to retire due to the revenue of other items Very Happy
Post  Lem Evans September 25th 2011, 5:34 pm
richter69 wrote:no broken pin worries here either...............external pump for the win.......... Basketball Basketball
Do not use green oil on the shaft during the gear install......it's so slick that no pin[s] will be able to retain the gear.
Post  Curt September 25th 2011, 5:48 pm
Thats all I was trying to say! Roll pin shearing Lmao
Post  jrocco September 25th 2011, 6:33 pm
Also check the distance from the bottom of the dist to the gear. If it is too long the gear will rub the block and shear the pin.
http://www.msdignition.com/instructions/Products/Tech_Info/gear_install_frm28590.pdf?terms=distributor+gear
Also make sure you are using a hardened pin. Most of the Silver pins at the hardware store are very soft.
jrocco
jrocco
Post  powerstrokeace September 25th 2011, 8:20 pm
Lem Evans wrote:When you replaced the pin last time did you put the 1/8" back in it or did you go bigger?
I put the 1/8" back in. And it was not a double rolled pin.
Ace
powerstrokeace
powerstrokeace
Post  powerstrokeace September 25th 2011, 8:21 pm
56Tbird wrote:Double pin it. I had one do it years ago in my motorhome.It only had 35,000 miles on it.I broke 3 of them before I double pinned it. I think it was probably getting wore where it had spun on the shaft. I put another below it a half turn away and never had another problem.
I never even thought about it.
Ace
powerstrokeace
powerstrokeace
Post  powerstrokeace September 25th 2011, 8:23 pm
Hmm
I never thought about that as well. May have to do this
Ace
powerstrokeace
powerstrokeace
Post  powerstrokeace September 25th 2011, 8:25 pm
BigDave65 wrote:I broke a pin a couple of years ago for the first time. I bought a bag of the mult-layer pins and have been just replacing it at the beginning of every season.
Yea that what I thought about. I fixed that dist I've been running for years and had a extra so I set it up the same (locked it out) and put a bronze gear on it so what this happened I cold just swap it in a few minutes.
Ace
powerstrokeace
powerstrokeace
Post  powerstrokeace September 25th 2011, 8:27 pm
I'm not even in that bracket.... No
powerstrokeace
powerstrokeace
