Trailer winch
Trailer winch
What type and how thick of metal will I need to install under the flooring for a winch ( pull car back into trailer ) ? Can it be bolted in or does it need to be welded ? This is a enclosed trailer if that helps.
Thanks in advance,
John
Thanks in advance,
John
John Myrick- BBF CONTRIBUTOR
Re: Trailer winch
I used some steel plate. I think it was 3/16" thick. Just what I had around. Prob a 9"X12" piece under the floor with holes drilled to match the winch base. The bolts are 7/16" grade 5. Works fine for the past 3 yrs.
Re: Trailer winch
we used 1/16 12x12 plate welded to cxm but as long as you have cxm on 16'' you will be fimd doing as the other has said but if the cxm is on 24'' centers I would weld it.
Re: Trailer winch
Ok thanks for the info guys. Hopefully I'll never need it but just incase....you just never know
Thanks again,
John
Thanks again,
John
» got me a new trailer
» New Trailer
» My trailer
» new Trailer
» 598 bbf a460 motor car roller or race ready 28 ft enclosed getting out
» New Trailer
» My trailer
» new Trailer
