how much gear lube for a 9'' 31 spline detroit locker ?
this is on my buddys 57 t bird tube chassie car, neither the rear housing or the center section have a fill hole. Im thinking 3 qts but want to make sure.
nuclearcobra- BBF CONTRIBUTOR
Re: how much gear lube for a 9'' 31 spline detroit locker ?
2 quarts will be plenty
Curt- Posts : 2791
3qts would be a good test for the axle seals
crittersf1- Posts : 521
I've always put about 2.5 quarts in..............
Well we filled it and it took 4 qts to bring it up to where the plug should be like moser said it would
I just have a factory housing for the time being, I dont know that a fabbed deal might take more????
The amount I use gets it to the bottom of the fill hole on the housing, its also below the axle tubes.
nuclearcobra wrote:Well we filled it and it took 4 qts to bring it up to where the plug should be like moser said it would
If you were afraid of going to fast, that will fix part of it.
Curt- Posts : 2791
For real i always wondered what this thing would run in the 1/4 but its a street car and a blast to drive even tho the poor thing is chubby powered at least its big chubby powered its a ZZ 502-502 with some tweakin done to itCurt wrote:nuclearcobra wrote:Well we filled it and it took 4 qts to bring it up to where the plug should be like moser said it would
No problem if it is a street car. I thought it was an all out drag car.
Curt- Posts : 2791
» looking for 35 spline detroit locker
» Dana 44 Detroit Locker 30 Spline
» 9" ford 3rd member with 3.89 gears and 28 spline detroit locker f/s
» garage sale ALL PRICES REDUCED--GOTTA GO
» How much will a Ford 9" rear Hold ?
