mustang swap question
'65 T-BOLT
JT557
mustang swap question Empty mustang swap question
Post  JT557 October 11th 2011, 5:50 am
someone told me i can use ford ranger rotors but what year ranger rotors will work for 88 mustang fox ?????? getting ready to change whole k-mem.and a arms .. so any info will be a big help..... thanx , JT557......
JT557
JT557
mustang swap question Empty Re: mustang swap question
Post  dfree383 October 12th 2011, 7:34 am
I ended up with a Stange Kit on the Front of mine.
Post  '65 T-BOLT October 12th 2011, 11:59 am
ford ranger rotors will be small in diameter... I think. I used the 98 and up mustang brakes on my 5 lug swap.... areospace brakes for these 98 and up spindles....expensive!......83 to 88 ranger rotors
'65 T-BOLT
'65 T-BOLT
Post  whatbumper October 12th 2011, 12:05 pm
I would use your 88 Fox spindles and find some used brake kits online. It would be better in the end and you will not have to go through all of the headache of finding the correct ranger stuff (which isn't hard but could be time consuming to find used stuff). I see this stuff on YB and other forums all of the time for sale.
Post  BigBlockRanger October 12th 2011, 2:28 pm
Ranger stuff only works for 4 banger, 6 cyl and all 79-86 cars with the smaller front brakes.
Mark VII rotors work for '87-93 5.0L cars I believe.
Post  JT557 October 12th 2011, 9:32 pm
thanx for your comments , i think i might try changing spindles and rotors from 95 gt i think that would solve problems.... probally have to change calipers also to match rotor size... thanx guys.....JT557.......
JT557
JT557
Post  bigblok2000ranger October 12th 2011, 9:40 pm
Been long time since I have messed with them but I remember something about having to chane balljoints if doing the SN-95 swap to a fox body or another option being to just buy the FRPP lower control arms that already have the newer geometry ball joints. Think it had something to do with bumpsteer. I would check into it though.
bigblok2000ranger
bigblok2000ranger
Post  zbob October 12th 2011, 10:40 pm
eric,,,correctto mundo....the taper isnt quite right. also now the fox body rack from flaming river will have too short tie rod ends...i found out the hard way on both, bobn
zbob
Post  whatbumper October 12th 2011, 10:53 pm
http://www.yellowbullet.com/forum/showthread.php?t=409724
Post  jbozzelle October 13th 2011, 11:09 am
The SN95 on up stuff will not clear most aftermarket wheeks. My Convo Pros hit the calipers.
My kit from Strange came in yesterday...
Post  bigblok2000ranger October 13th 2011, 9:29 pm
I found with the SN-95 and my Weld Pro-stars that a 1/4" spacer worked perfectly, but the way IHRA/NHRA rules were about wheel spacers what I did was drill and tap 5 holes through the spacers with counntersunk 1/4-20 scerws as that theorectically made them part of the rotors at the time.
Where mine hit was the support bar for the caliper brackets I even thought about grinding the 1/4 off of that for about 5 or 6 minutes then realized there was a reason for that brace.
bigblok2000ranger
bigblok2000ranger
Post  jbozzelle October 13th 2011, 9:41 pm
My wheels still hit the caliper. I was using the SN95 spindles and 99 up brakes.
mustang swap question Empty re
Post  JT557 October 14th 2011, 4:56 am
jbozzelle wrote:My wheels still hit the caliper. I was using the SN95 spindles and 99 up brakes.
i'm now tryin to get right stuff from a guy on other site so thanx for tellin me about what to be aware of guys , all of this is sure gonna save me time and money,and for that i am greatfull.....thanx JT557......
JT557
JT557
