Looking for 460/429/514/521 etc
+6
SMOKEY
466-FOX
deerhunter3814
Copperhead
machwon169
10 posters
Looking for a 429-460 or stroker... Looking for something that can take 200shot of spray... So forged pistons a must... Rods would be great to but stock wot bolts should be ok....
Heads can be anything... Stock ported heads.. Cj heads... Etc....
Looking for a 500-600hp engine 500-600 torque... Naturally aspirated...
Looking for 9.1 to 10.8 compression to run on pump 93....
Be awesome if you had times of the motor or times of a build like it...
Also could trade sbf parts and other stuff and have cash....
machwon169- Posts : 47
Re: Looking for 460/429/514/521 etc
How about an A-460 headed 557 that dyno'd 838hp @6300 / 776tq @4800 ?
10:8 to 1 Compression,.......and set up for a 150 shot
Less than 24 passes since freshening up in the spring. Only one pass made on a 100-shot of N20 for less than 6 seconds.
Copperhead- Posts : 492
Too bad you need a low compression engine.
I would give you a good deal on a D0OE headed all forged rotating, A-460 block 547 built by Jet Boat BOB.
deerhunter3814- Posts : 144
I have a 466 with a forged bottom end, blue thunder heads, victor, dominator, etc... runs 10.40's on pump gas.
466-FOX- Posts : 4
460 ENG.
We have a 460 with 429 heads .CJ cam. 750 Holley df. Headers. C6 trans. Trade for Stock 302 & Trans. You take te 460 out. And put the 302 in the truck. We have tools. Just to much for this old man. Thanks SMOKEY.
SMOKEY- Posts : 1
machwon169 wrote:Looking for a 429-460 or stroker... Looking for something that can take 200shot of spray... So forged pistons a must... Rods would be great to but stock wot bolts should be ok....
Im going to have a few different engines for sale in a week or to, a 514,and a 466, and maybe another
-rich
BOSS 429- Posts : 2372
deerhunter3814 wrote:Too bad you need a low compression engine.
Could you give more specifics on your 547?
I already have DOOE heads; would you be willing to separate?
STR-LGL-70- Posts : 223
533
I have a 533 with Aluminum 429/460 Super Cobra jet heads. Forged crank and Eagle H beam rod with ARP 2000 bolts and SRP flat top pistons.
460 Torker intake. Ran it with a 1050 Domi.
dhoma@new.rr.com
Dan
dhoma@new.rr.com
Dan
STR-LGL-70 wrote:deerhunter3814 wrote:Too bad you need a low compression engine.
I would consider selling the short block, I will send you a PM with my phone number. If you don't recieve the PM let me know.
Thanks,
David
i got 473 elderbrk per. rpms ported
eagle h-beams
eagle crank
probe pistons 11.1 comp
and so on
runs 6.30s-1/8 at 3200.00
went 5.86-1/8 on 100 shot on pump gas
call me if interseted tell u more 870-926-0993
eagle h-beams
eagle crank
and so on
michealj- Posts : 78
michealj wrote:i got 473 elderbrk per. rpms ported
eagle h-beams
eagle crank
and so on
Waste of time my friemd, this thread is just window shoping.
Sorry the devil made me post this.
Yup already have my bottom end and heads... No delete feature
so change the title.... and say "NO LONGER NEEDED"
