How hot can a CRANK get?
blown86hallet
How hot can a CRANK get? Empty How hot can a CRANK get?
Post  blown86hallet November 9th 2011, 2:12 pm
Quick lube place, only 5 qts added to the diesel. ~WTF~!
Rod journal, got so hot the piston pin was able to mold it's self into the crank.
Crank material welded onto the pin.
Rods broke, window in block, no oil at all (would of been on fire) still running at dealership..
6.7L
How hot can a CRANK get? IMG_1828
How hot can a CRANK get? IMG_1819
How hot can a CRANK get? IMG_1820
How hot can a CRANK get? IMG_1821
How hot can a CRANK get? IMG_1823
How hot can a CRANK get? IMG_1827
How hot can a CRANK get? IMG_1825
How hot can a CRANK get? IMG_1824
blown86hallet
blown86hallet
How hot can a CRANK get? Empty Re: How hot can a CRANK get?
Post  Lem Evans November 9th 2011, 2:18 pm
How may qts was it supposed to have ? 12qts.?
Post  Curt November 9th 2011, 2:21 pm
I think most of that will polish out. May have to go 10/10 on the crank.
Post  richter69 November 9th 2011, 2:23 pm
ahhhh just pay the warranty claim and go on................no responsibility on anyones part
if you guys would tie the oil light into the radio or blue tooth it would be at the dealer in a heartbeat!
Post  blown86hallet November 9th 2011, 2:25 pm
richter69 wrote:ahhhh just pay the warranty claim and go on................no responsibility on anyones part
Then the wife would just turn the radio up louder, cause even more issues.
13.......
blown86hallet
blown86hallet
Post  56Tbird November 9th 2011, 2:56 pm
Gotta love them minumum wage guys who have no idea what they're doing! Did they take the low oil shutdown off the newer diesels? That mother got HOT!!
56Tbird
56Tbird
Post  dfree383 November 9th 2011, 3:00 pm
Ahhhh Yes..... The 19.95 Special....... With some zit faced, snot nosed, punk, in charge of the shop !!!! now that's "Value" cyclops
Post  342g November 9th 2011, 3:30 pm
You say that was still running, when they brought it in, impressive, but as Dan ask, did they do away, with the low oil shutdown, if so, why?
342g
342g
Post  blown86hallet November 9th 2011, 3:40 pm
342g wrote:You say that was still running, when they brought it in, impressive, but as Dan ask, did they do away, with the low oil shutdown, if so, why?
what engines had that switch? 7.3L and 6.0L..? High oil pressure system ran the fuel injectors.
NO need for it on the 6.7L
Do any gas engine have the switch?
blown86hallet
blown86hallet
Post  richter69 November 9th 2011, 4:58 pm
no oil shutdown on um, the 7.3/6.0 would quit running after they get about 9-10 quts low due to the oil being foamed up so bad the HP pump could not maintain enough oil press to actuate the HUEI injectors.
We did have a 6.7 in here a few months back that was knockin its ass off, it was full but it was a beat to hell farm truck. we told them it would take 3 weeks to get it in (which at the time was true) so they hauled it up to okc which was fine by me.
Post  56Tbird November 9th 2011, 7:46 pm
My truck shut down when it was about 4 quarts low.But ,it actually shutdown from low oil pressure to the HUEI injectors . Is that right Fabio? I'm just glad it shut down when it did..no harm ,no foul this way.At least my crank is still crankin!! cheers
56Tbird
56Tbird
Post  richter69 November 9th 2011, 7:49 pm
yep you lost the line from the HP pump to the cyl head.
We used to have a dipshit lube tech years ago that left a drain plug loose on a 7.3, needless to say a tow and 15 qts of oil later it was fine. I know the old guy that has it and it has well over 400k on it now on the original engine.
A 6.4 and a 6.7 will run with no oil lol
Post  56Tbird November 9th 2011, 8:04 pm
They just won't make any long distance trips with no oil Laughing I like the 7.3 set up, might have to replace a line sometime ,but not the engine!
56Tbird
56Tbird
