Adapter 4R70W to BBF 460
jrocco
Adapter 4R70W to BBF 460 Empty Adapter 4R70W to BBF 460
Post  jrocco November 13th 2011, 11:10 am
I am researching adapters to bolt a 4R70W to a 460. So far I have found:
Bendten's - $795.00 http://www.transmissionadapters.com/Ford%20429-460.htm
JW UltraBell - $385.00 - Requires machining off transmission bell
http://www.summitracing.com/parts/JPT-92454-AOD/
Lentec 6A369-ADP-429 - $495.00 http://www.lentechautomatics.com/aodpricing.html
Recommendations?
Are there any others?
jrocco
jrocco
Adapter 4R70W to BBF 460 Empty Re: Adapter 4R70W to BBF 460
Post  whatbumper November 13th 2011, 4:46 pm
I think I would use the jw for the quality and price. You just cut the factory bell off with a cheap saw and bolt the new one to the pump. No expensive machining needed.
Post  cooter November 13th 2011, 9:05 pm
just courious, if you are going to use an adapter then why not use a much better 4L80 transmission?
cooter
Post  jrocco November 14th 2011, 1:56 am
cooter wrote:just courious, if you are going to use an adapter then why not use a much better 4L80 transmission?
That transmission is about the same size as a BBF. Heavier also.
jrocco
jrocco
Post  windsor November 14th 2011, 2:03 am
I'm pretty sure that Lentech adaptor is just a rebranded JW - meaning it's the exact same piece for $100 more. But, from what I've seen/heard this is the way to go.
I have one on an AOD for BBF and it seems to fit well.
Adapter 4R70W to BBF 460 Img_0310
Adapter 4R70W to BBF 460 Jw_bel10
Adapter 4R70W to BBF 460 Img00213
Post  jrocco November 14th 2011, 2:12 am
windsor wrote:I'm pretty sure that Lentech adaptor is just a rebranded JW - meaning it's the exact same piece for $100 more. But, from what I've seen/heard this is the way to go.
Thanks for the photos. That helps alot. Did you cut off the bell or have someone do it?
Also what size converter can you get in that bell?
jrocco
jrocco
Post  David Cole November 14th 2011, 7:01 am
One other option:
You can get an adapter ring. You cut the bellhousing off and use the ring that allows you to use a stock Ford fmx bellhousing. The fmx bellhousing is bolt on of course. Likely oem apps were mid 70's cars with a 351M/400 .
http://www.broaderperformance.com/en/ford-aod/119-aod-adapter-plate.html
Post  cooter November 14th 2011, 8:47 am
As for the 4L80, they are big and heavy but imho if you need to buy an adapter and controller then why not use the strongest tranny available?
cooter
Post  windsor November 14th 2011, 9:01 am
That's interesting looking, David. Must be a new product. I know Broader does good work.
jrocco, I believe a C6 convertor must be used, but don't quote me on that.
I had to have the bellhousing milled off, didn't do it myself.
Talk to SilverFox Racing Transmissions, also, he's very good and reasonably priced with AOD's. http://www.silverfoxtrans.com/silverfoxtrans.com/Home.html
Also check out .www.clickclickracing.com for good technical support on AOD's. (Silver Fox's forum site).
AOD transmissions require no electronic controls. AOD-E/4R70W trannies, do
Post  whitefield November 14th 2011, 10:02 am
windsor wrote:That's interesting looking, David. Must be a new product. I know Broader does good work.
X2 and I used some of your research , good info
whitefield
whitefield
Post  jrocco November 16th 2011, 6:55 pm
I called JW and asked for a copy of the instructions for cutting off the bell. They did not really want to discuss with me. Said the instructions would be shipped with the adapter, but it would be best to talk with FB Performance Transmissions because they had purched some. Thought this was kind of odd.
windsor wrote:
AOD transmissions require no electronic controls. AOD-E/4R70W trannies, do[/url]
I decided to go with a manual valve body for this transmission. No electronic controls required this way.
jrocco
jrocco
Post  jrocco November 21st 2011, 3:11 pm
Well I got really confused this morning.
Eric from JW said their Bell adapter only works with AOD's not AOD-E or 4R70W.
He said his understanding was that the AOD-E and 4R70W were completely different from the AOD.
jrocco
jrocco
Post  windsor November 22nd 2011, 1:37 am
I'm pretty sure that's correct.
Please call Dan at Silverfox or visit www.clickclickracing.com They have some awesome tech on these trannies there.
