Best 460 cj intake gaskets
Best 460 cj intake gaskets Empty Best 460 cj intake gaskets
Post  droppedf100 November 13th 2011, 9:12 pm
Hey haven't posted in awhile. Something broke on cylinder 4 either a piece of valve or ring land but its showing 125lbs and all other cylinders are between 160-175lbs and it beat the plug up. Anyway im pulling it apart this week and need to know what intake gaskets to run. I need cj gaskets to work with a victor and victor matched TFS streets. I've been running Felpro 1231s but im having trouble with the water ports leaking or blowing out.
droppedf100
droppedf100
Best 460 cj intake gaskets Empty Re: Best 460 cj intake gaskets
Post  John Myrick November 13th 2011, 9:16 pm
Fel-Pro Q1231S3 are .005 thicker and have a steel core.
Post  droppedf100 November 13th 2011, 10:14 pm
John Myrick wrote:Fel-Pro Q1231S3 are .005 thicker and have a steel core.
I went through Summit and saw these just now. Have you used them? They are expensive but ill spend double if they work.
droppedf100
droppedf100
Post  John Myrick November 13th 2011, 10:20 pm
No, just the 1231's. The steel core should keep them from blowing out though.
Post  BOSS 429 November 14th 2011, 2:38 am
droppedf100 wrote:Hey haven't posted in awhile. Something broke on cylinder 4 either a piece of valve or ring land but its showing 125lbs and all other cylinders are between 160-175lbs and it beat the plug up. Anyway im pulling it apart this week and need to know what intake gaskets to run. I need cj gaskets to work with a victor and victor matched TFS streets. I've been running Felpro 1231s but im having trouble with the water ports leaking or blowing out.
shouldnt be having a problem with these, intake not matted right, angle off, ect?
Post  Gregaust November 14th 2011, 5:55 am
Yep those 1231's are junk, only designed apparently for short term use .. Search on here or other 460 site you'll find very common problem moving and leaking around coolant passages. The steel core ones may be better . Based on recomendations on these BB sites the Victor Reinz Nitro seals 95074SG have been excellent for me . Got mine from Carquest no probs ..
I believe also SCE and MrGaskets have given guys here good service .. Here's some info in the link from the past
http://www.460ford.com/forum/showthread.php?t=98886
Gregaust
