Snap C6 tailshaft
planotorino
Snap C6 tailshaft
The engine motor mount have the isolator (rubber) but it is pined with a bolt. The trans have a solid mount
I had the car on the Dyno and after the first pull it started leaking fluid and after the second pull it was a leaking good. Here a picture of it. Anyone have any idea what can cause this? Thanks in advance.
planotorino- Posts : 8
Re: Snap C6 tailshaft
Motor moved, tailshaft didn't.
I recommend a rubber or poly trans mount.
whatbumper- Posts : 3024
So the engine and transmission mount need to be the same. thanks
Always a rubber mount on the trans, even with solid motor mounts.
A solid trans mount with rubber motor mounts will for sure do what your did..................
X2................
Like they said, factory/stock auto trans cases should always get some form of a flexible tailshaft mount regardless of what style engine mounting is used in a door car.
A few guys do solid mount the beefier aftermarket auto trans cases (from say JW, Reed, ATI) but I wouldn't recommend it. Case flexing can still sometimes have an effect on the valve body with an aftermarket case too.
DILLIGASDAVE- Posts : 2262
Agree...agree....Agree.....flexible mount for me!
Everyone that I know that has broken a tail housing, either was involved in a bad accident or had a solid mount.
Keith
Keith
WOW I must be pretty lucky I got a plate front ,mid and solid trans , been hitting it with125 shot.I have broken a alot of things on this car but never the tailshaft Guess that might be a winter project to change this over to a rubber tailshaft mount
dave d- Posts : 809
