c4 converter
c4 converter
need a c4 converter 3000+ range with 24 spline input
johndickjr- Posts : 896
"Fresh" C-4 BBF or SBF 8" Race Converter
have a 8" -Dynamic/ Abruzzi torque converter with just 2 passes on it after freshened up and made (Spragless.)..No Parts to Break and very consistant.,117/16 Bolt pattern.. I left at 4800 on a transbrake in a BBF but would also make a great SBF on a power adder converter. I just put$400.00 in it but I'm changing combo so this must go !!! call Jack 440-479-0655
Asking-$275.00 obo I'm in Northeast Ohio...(Mentor )have pics I can send
smackjack- Posts : 16
Re: c4 converter
24 spline ?smackjack wrote:have a 8" -Dynamic/ Abruzzi torque converter with just 2 passes on it after freshened up and made (Spragless.)..No Parts to Break and very consistant.,117/16 Bolt pattern.. I left at 4800 on a transbrake in a BBF but would also make a great SBF on a power adder converter. I just put$400.00 in it but I'm changing combo so this must go !!! call Jack 440-479-0655
c-4 convertor
Is that the small shaft of the two.. If it's the small shaft one i have a 3500 stall thats got about 5 1/8 mile pass on...
557 mazda- Posts : 101
Re: c4 converter
I have a UCC 10" that Lenny built for our old 466 pump gas deal, I think it was built to be around 3800-4000 with about 500 hp or so, I'm pretty sure its the larger 26 spline shaft, which if I remember you can just swap the shafts out???? man its been too long since I messed with that stuff to recall.
Re: c4 converter
[quote="johndickjr"]
I was running a hardened 26 spline input
24 spline ?[/quotesmackjack wrote:have a 8" -Dynamic/ Abruzzi torque converter with just 2 passes on it after freshened up and made (Spragless.)..No Parts to Break and very consistant.,117/16 Bolt pattern.. I left at 4800 on a transbrake in a BBF but would also make a great SBF on a power adder converter. I just put$400.00 in it but I'm changing combo so this must go !!! call Jack 440-479-0655
Re: c4 converter
the shaft are actually bigger ..only reason i i need a 24 spline is i have nearly new c4 , siting here..richter69 wrote:I have a UCC 10" that Lenny built for our old 466 pump gas deal, I think it was built to be around 3800-4000 with about 500 hp or so, I'm pretty sure its the larger 26 spline shaft, which if I remember you can just swap the shafts out???? man its been too long since I messed with that stuff to recall.
Re: c4 converter
yes is has a smaller shaft..557 mazda wrote:Is that the small shaft of the two.. If it's the small shaft one i have a 3500 stall thats got about 5 1/8 mile pass on...
» New Ultimate Converter Concepts Converter Test Results-Updated
» NOS converter
» Early 429 crank pilot diameter
» wanted c6 converter----roller lifters
» C4 converter
» NOS converter
» C4 converter
