6cyl F150 to a 460/C6 set up
hillbilly pony
6cyl F150 to a 460/C6 set up Empty 6cyl F150 to a 460/C6 set up
Post  hillbilly pony November 26th 2011, 3:50 pm
anyone hve details on what is needed to sit a 460 where a 6cy used to be?
hillbilly pony
6cyl F150 to a 460/C6 set up Empty Re: 6cyl F150 to a 460/C6 set up
Post  69F100 November 26th 2011, 5:03 pm
Justin will need the 460 engine stands for the frame just to start with what year truck you have that way they will know what years will work for you.
Post  schmitty November 26th 2011, 8:08 pm
Like Jim said, we need to know what year truck before a list can be put together, and also is this a 2wd or 4wd? Cool
Post  hillbilly pony November 26th 2011, 11:10 pm
yeah...sorry about that.
1993 2wd standard cab. its gonna be carb.
hillbilly pony
Post  61coon November 27th 2011, 12:37 am
I think you can use 93-97 F250 2wd engine stands and motor mounts for this swap.Not sure about the transmission mount?But then again,I don't see why the trans mount wouldn't work too.Someone correct me if I'm wrong.I don't wanna lead someone in the wrong direction.---RED
61coon
61coon
Post  whitefield November 27th 2011, 12:43 am
Engine Stands from 80 to 97 Ford trucks with a 460 will work. The engine stands are bolted and riveted in. good luck
whitefield
whitefield
Post  bluovldude December 4th 2011, 9:31 pm
the trans crossmember from the same truck will work, but the ears bolting it to frame are different from 2wd to 4wd
bluovldude
