4.390 none file fit rings
where can a guy buy standard plasma moly piston rings for 4.390 bore 1/16 1/16 / 3/16 none file fit ?
10SHOTS- Posts : 587
none file fit rings
From what I have bought none file fit rings arent available .Maybe I am wrong on this but the several sets I have bought in the same size you need all where file fit .Give this guy a call Chris at barnett performance in atl Ga.800 533 1320 or 404 522 1320 ask for Chris .I just bought a set of mahle moly rings in the same width you requested file fit for less than $125 .Maybe he knows of something that doesnt need fitting to your bore .Doug
manofmerc- BBF CONTRIBUTOR
Re: 4.390 none file fit rings
Lem or Randy Should be able to get you something to. Even with the non-flie set you still need to check them and my need to fit them some, depending on the use.
File fitting rings is really simple and easy too do imo. Just about 3hrs from your day
» What's everyone using to file piston rings?
» what rings to use
» piston rings
» What rings to use
» Do make a ring set for .060 piston that i would not have to file fit
» what rings to use
» piston rings
» What rings to use
