High Idle and Surge
+6
pro64
blu69MachI
10 posters
High Idle and Surge Empty High Idle and Surge
Post  blu69MachI December 14th 2011, 2:20 pm
Hello everyone I've been reseaching this for a while and I still havent found anything to cure this issue. I hope someone can assist.
I have a 466 and it idles right at 1700rpm with a little surging. It has a Victor intake with a Hardcore series 1000cfm carb on top of a 1"spacer with a vacuum port. It had came with a 930cfm and was idling high 1500 with that too. I have the idle down far enough to where the linkage is no longer moving. I replaced gaskets between the carb and intake. I tried the spraying carb cleaner method. It has a hydraulic cam the person I bought it from says it has a Lunati voodoo cam. Timing is set to initial 12 degrees. A/F is adjusted to 1 1/2 turns out. When I hooked up a vacuum gauge to the port below the carb it was bouncing all over the place. The port goes to vacuum can and transmission. I had even put a cap on the intake port. I have been reframing from posting this on here until I reach my wits end. I can't think of anything else to check, any info would be appreciated. Thanks!
blu69MachI
blu69MachI
High Idle and Surge Empty Re: High Idle and Surge
Post  dfree383 December 14th 2011, 2:26 pm
Big Vac Leak Somewhere.
Tell us more about the combo.
Post  blu69MachI December 14th 2011, 2:54 pm
1968 block and 1968 heads 75cc, crane ignition, factory electronic distributor with vac adv blocked. This is all in Park.
blu69MachI
blu69MachI
Post  dfree383 December 14th 2011, 3:02 pm
try putting some timing to it also, with the vac stuff blocked your way retarded on the timing.
Post  blu69MachI December 14th 2011, 3:06 pm
ok, I will try to do that tonight
blu69MachI
blu69MachI
Post  blu69MachI December 14th 2011, 6:44 pm
well tried advancing and its still doing the same thing. I'll keep searching other avenues
blu69MachI
blu69MachI
Post  pro64 December 14th 2011, 7:09 pm
reseal intake manifold to heads.inspect for cracks. carb spacer gaskets carb gaskt good luck...... : Exclamation
pro64
Post  schmitty December 14th 2011, 10:18 pm
Do you have a brake booster? If so, unplug it and see if the booster is bad. Cool
Post  cool40 December 14th 2011, 11:03 pm
intake may have a leak on the bottom.pull the oil cap and see if anythings comen out.
Post  bbf-falcon December 15th 2011, 11:56 am
All of that and also check carb base plate and spacer for cracks.
Post  blu69MachI December 16th 2011, 9:50 am
retorqued the intake, going to pull the carb spacer tonight.
blu69MachI
blu69MachI
Post  dfree383 December 16th 2011, 2:40 pm
Seal the 2 outer valve cover bolts?
Post  strokedmyford December 16th 2011, 3:28 pm
1.eliminate all possible external vacuum leaks
2. remove and plug pcv valve if you have one, plug all other crank case vents
3. remove oil cap while engine is idling place the palm of your hand over the oil fill hole making the inside of the engine air tight. The engine should create a slight pressure as it runs, if you feel a vacuum on the palm of your hand engine tear down is necessary if not engine is sealing fine.
Cam timing has caused werd things also, I have ran across a couple of engines that some did not or know how to line up timing marks and run fine but rev them up a bit and man what a surge, mostly timing belt stuff though. One was a 460 in an 89 f250 that hit a cow and the body shop went ahead and replace the timing chain, front cover, and water pump that was damaged in the accident and they lined it up a cog off, farmer ran the truck for years but it would not rev up passed 2500 without a bad surge. Finally showed up at my shop after thousands were threw at it trying to cure the issue and after investgating when it started I went for the timing chain and sure enough cured the issue. I have also had to jump cog on the chain to bring the cam into time. At this point it should be checked to eliminate it being an issue. Hope this helps
strokedmyford
strokedmyford
Post  blu69MachI December 17th 2011, 8:55 am
First off I want to thank you all for giving me ideas on this. I checked everything and it still idles at 1700 rpm in Park. I'm starting to believe that this is just the way it's going to be. When I put the car in gear it drops down to about 900, The car is running very well and the oil is clean so I'm thinking, it is what it is untill I build a new engine for it. Once again thanks for the help.
blu69MachI
blu69MachI
Post  LivermoreDave December 17th 2011, 10:13 am
Seems most external options have been covered. How about increasing the main jet size by 5 numbers? Oh by the way, a can of starting fluid works great on those hard to find vacuum leaks.
Dave.
LivermoreDave
Post  crittersf1 December 18th 2011, 10:57 am
Propane works well also for finding that "elusive" vacuum leak
crittersf1
crittersf1
Post  blu69MachI January 5th 2012, 4:59 pm
I decided to pull the engine apart for a cam swap and I found that the cam thrust plate had broken and the bolt was holding it in place. So I'm glad I pulled it apart. After research I think I'm going to look for a bronze thrust plate as recommended by many.
blu69MachI
blu69MachI
Post  bbf-falcon January 5th 2012, 5:44 pm
Call Lem,he prob. has them in stock Smile
Post  blu69MachI January 5th 2012, 5:48 pm
I just PM'd him about a cam recommendation too. I had already placed a cam order with summit for a comp cam but it's on back order so they are giving me the option to cancel. After further research I found it is highly recommended to have a custom grind so the plan is to get a cam from Lem too. I'm steady learning alot from the folks on this site.
blu69MachI
blu69MachI
Post  dfree383 January 5th 2012, 5:49 pm
Good move, most of the shelf stuff leaves alot on the table.
Post  powerstrokeace January 5th 2012, 9:35 pm
I know this is a little late but I bet the cam/rockers was adjusted to tight. This will cause just what your talking about. I set my hyd cams at 1/4 tight just as soon as the push rod play is taken up or you can't roll it with your fingers.
Ace
powerstrokeace
powerstrokeace
