Is this repairable?
71460cougar
Is this repairable?  Empty Is this repairable?
Post  71460cougar December 23rd 2011, 11:58 pm
I think I have the pic included, area around the oil pump drive/ base of dist gear is cracked.
71460cougar
Is this repairable?  Empty Re: Is this repairable?
Post  res0rli9 December 23rd 2011, 11:59 pm
no pick scratch
Post  71460cougar December 24th 2011, 12:01 am
Is this repairable?  058
71460cougar
Post  71460cougar December 24th 2011, 12:04 am
I cant figure out how to post the pic!
71460cougar
Post  res0rli9 December 24th 2011, 12:08 am
ask if you can email them to some one on here to post the pic's.
Post  71460cougar December 24th 2011, 12:43 am
if I email the pic to someone could they post it for me. I am to new I guess
71460cougar
Post  richter69 December 24th 2011, 1:21 pm
richter69@suddenlink.net
Post  bigblok2000ranger December 24th 2011, 3:11 pm
The block would need to be welded with nickel rod and remachined in that area I would think you are easily looking at~$200 the question is, is the block worth investing that into which only you can decide.
bigblok2000ranger
bigblok2000ranger
Post  71460cougar December 26th 2011, 12:25 am
is it worth it if it is a D0ve-a block? it is bored something over, according to family. balanced and blueprinted. like I said, I only have hear say, no much for records. I was a ase master tech for 10 years, move on to another type of service work. I was never a HP type guy until it became more of a hobby. I have a solid understanding of how engines wok , just get nervous about hi pro stuff. never really a carb guy either.
71460cougar
Post  466cj December 26th 2011, 3:09 am
D0VE-A blocks tend to be worth more than other production blocks. Good used cores can get $100 - $300 all depending on location and condition. If it is a 4 bolt main block it is worth a bit more. Since the engine has been rebuild have to consider cost to have another block checked out and machined.
If it was mine I'd take it apart and inspect the block. Provided everything else on the block is good I'd get it repaired. Just have to find a good shop capable of properly fixing it.
Steve
466cj
Post  racnrick December 26th 2011, 3:17 am
racnrick
