TTB oil filter FIGHT
Anyone else have problems with the front diff smashing the oil filter? I have no suspension lift. I never noticed it being that close.. I only noticed it when I was pulling the engine out. Also can I run the 1.5" lift front coils without changing anything else?
FORDMUD- Posts : 290
Re: TTB oil filter FIGHT
I believe there is a "short" filter that can be used, because without a lift or some type of taller bump stop, damage is going to happen if you play in the rough stuff. Yes I believe you can run a 1.5" lift spring without much trouble. You will need to have it checked by an alignment shop, and to get proper tire geometry, they will use some offset bushings to get the proper camber on the tires.
schmitty- Posts : 4538
Rancho RS6418 is a nice spring to run, it raises the front about 1.5-2 inches and no drop brackets needed.
strokedmyford- Posts : 126
» then the fight started
» Listening to the fight
» and thats how the fight started
» What filter for c6
» Lifters and Oil Pressure
