cu inch ?
cu inch ?
i been doing that fomula over and over again on my calulator . its good to have it in writing now,
thanks
i read that the differance in the 533 vrs the 557 is mid range tq, on the 557 right ? this was a 1998 book .
if my chassis is not messed up i might go big ! so the biggest stoke you can fit in a stock 460 block is what ? 4.500 ? and is .080 over bore the biggest bore also ? or is there more to be had?
at .080 is 4.440 you cant go 4.500 ? thats only .060 more or .030 per side on the cylinder.
and what year blocks to stay away from and whats the best or okay blocks
thanks
thanks
thanks
2fox- Posts : 275
Re: cu inch ?
Re: cu inch ?
You need to sonic any block you want to take to .080, alot will go their with out issue, but its sometimes pretty random, no factory 2 bolt blocks are better than others. although D9TE stuff does have deeper skirts on the bores and DOVE-A blocks are easiest to convert to 4 bolt mains.
If you looking at building a big motor, most of the time its best to just bite the bullet now and get a A460 or Eliminator block, you'll be ahead in the long run.
Re: cu inch ?
You can also go in-between those bore sizes with a 4.470 bore.
BigDave65- Posts : 567
