TA 31 silicone question
I used it on the ends of the manifold. Now how long after installing the manifold do you have to let the TA 31 set ? 1 hour, 8 hours or is it best to let it sit overnight ?
Thanks in advance,
John
Thanks in advance,
John
John Myrick- BBF CONTRIBUTOR
Re: TA 31 silicone question
Stuffs pretty tough, I give it 4-6 hours and let'er rip.
if the crankcase is vented it should be fine, if it fas an evac or vac pump overnight would be best.
Just has a PCV and breather. Dark here now so it will sit overnight. I hate freakin leaks
Engine isn't high enough horsepower to require a vac pump.
Thanks guys
Thanks guys
» Epoxy or silicone gas resistant
» Custom oil pan- gasket or silicone?
» Silicone in head bolt holes - how to remove?
» n2o question
» n2o question
