BBF SOLID ROLLER CAMSHAFTS AND ONE SET USED COMP CAMS SOLID ROLLER LIFTERS
JR Performance Motorsport
Tennessee Bullitt
studly
BBF SOLID ROLLER CAMSHAFTS AND ONE SET USED COMP CAMS SOLID ROLLER LIFTERS Empty BBF SOLID ROLLER CAMSHAFTS AND ONE SET USED COMP CAMS SOLID ROLLER LIFTERS
Post  studly January 7th 2012, 10:26 pm
Comp cams
1. 114 lobe sep 114 centerline 284 @50 intake 302 @50 Exhaust with 1.73 rockers 816 lift intake 780 exhaust $250.00 shipped
2. 114 lobe sep 112 centerline 288 @50 intake 302 @50 Exhaust with 1.80 rockers 817 lift intake 810 exhaust $250.00 shipped
3. Comp Cams Solid roller lifters used $200.00 shipped
Both cams were ground for a460 headed BBF
studly
studly
BBF SOLID ROLLER CAMSHAFTS AND ONE SET USED COMP CAMS SOLID ROLLER LIFTERS Empty Re: BBF SOLID ROLLER CAMSHAFTS AND ONE SET USED COMP CAMS SOLID ROLLER LIFTERS
Post  Tennessee Bullitt January 9th 2012, 7:01 am
pm'd ya.
Tennessee Bullitt
Tennessee Bullitt
Post  studly January 9th 2012, 11:21 pm
camshaft number 1 full specs
valve at intake adjustment .018 intake
valve adj exhaust .020
duration .050 intake 288 rocker arm ratio 1.80
duration .050 exhaust 302 exhaust arm ration 1.80
valve lift intake .817 lobe lift .4540
valve lift exhaust .817 lobe lift .4500
duration .020 317 intake 340 exhaust
cam advance 0
valve timing .050
open intake 32
open exhaust 87
valve closed intake 76
valve closed exhaust 35
cam journal diameter std 2.124
camshaft number 2
valve adj intake .026
valve adj exhaust .028
duration at 50 intake 284 rocker arm ratio 1.73
duration at 50 exhaust 302 rocker arm ratio 1.73
valve lift intake .816 lobe lift .4720
valve lift exhaust .780 lobe lift .4510
duration at .020 intake centerline 114
tappet lift intake 324 exhaust 340
valve timing@50
open intake 28
open exhaust 85
valve closed exhaust 37
journal diameter 2.124
studly
studly
Post  studly January 13th 2012, 11:23 am
still for sale
studly
studly
Post  studly January 23rd 2012, 7:43 am
ttt
studly
studly
Post  studly January 29th 2012, 6:19 pm
ttt
studly
studly
Post  JR Performance Motorsport January 29th 2012, 10:49 pm
How much time is on the lifters ?
http://www.e-PerformanceMarine.com
Post  studly January 30th 2012, 11:22 pm
the lifters probably have 100 passes on them somebody asked for pics today so i will try to post some tomorrow
studly
studly
Post  tconnection January 31st 2012, 11:01 am
Hey, i got bout the same cam plus i have the aheads that has the 1.640 dia springs on them. What rocker arm do you run? I mean like alum. or ss.
tconnection
Post  studly January 31st 2012, 9:15 pm
T&D SHAFTS ALUM WITH STANDS WELDED
studly
studly
Post  studly January 31st 2012, 9:20 pm
BBF SOLID ROLLER CAMSHAFTS AND ONE SET USED COMP CAMS SOLID ROLLER LIFTERS Compcams114on114002
studly
studly
Post  studly January 31st 2012, 9:25 pm
BBF SOLID ROLLER CAMSHAFTS AND ONE SET USED COMP CAMS SOLID ROLLER LIFTERS Compcams114on114003
studly
studly
Post  studly January 31st 2012, 9:27 pm
the 817 817 cam is no longer for sale
still have the 817/780 cam left and one set of comp solid roller lifters
studly
studly
BBF SOLID ROLLER CAMSHAFTS AND ONE SET USED COMP CAMS SOLID ROLLER LIFTERS Empty ROLLER LIFTERS
Post  1970 ford maverick June 2nd 2012, 6:09 pm
studly wrote:the 817 817 cam is no longer for sale
Do you still have the solid roller lifters for sale? THNX MAVMAN
1970 ford maverick
1970 ford maverick
Post  studly June 19th 2012, 1:45 pm
yes still have them.
studly
studly
Post  fordmonsta December 30th 2012, 11:27 am
you still have a set of lifters for sale?
fordmonsta
Post  studly December 30th 2012, 5:08 pm
I will have to check to see if i still have a set
studly
studly
BBF SOLID ROLLER CAMSHAFTS AND ONE SET USED COMP CAMS SOLID ROLLER LIFTERS Empty solidroller/lifters
Post  No.1Stunna! January 27th 2013, 6:28 pm
im new to this site but lots of parts im trying to c if u still have the big block lifters for sale very interested
No.1Stunna!
http://mrs_1stunna@hotmail.com
Post  studly January 27th 2013, 8:37 pm
nothing left all gone sorry
studly
studly
