HOLES IN HEAD
dave d
HOLES IN HEAD Empty HOLES IN HEAD
Post  dave d January 15th 2012, 4:15 pm
Hey need input on this one.Got a set of trick flow heads and cleaning the runners up noticed holes in the top of intake runners,where they drilled thru for the rocker studs, how much loss is this going to be on flow.These will see most of there life on the street,but still want a good set of heads,should I expoy these shut. Will be on a 545 Any thoughts THANKS Dave
dave d
dave d
HOLES IN HEAD Empty Re: HOLES IN HEAD
Post  richter69 January 15th 2012, 4:36 pm
when you put the rocker studs in be sure the holes are oil free, apply a bit of red locktite to seal the threads and you are fine. No need to fill the hole.
Post  QtrWarriorLady January 15th 2012, 5:24 pm
X 2
QtrWarriorLady
QtrWarriorLady
Post  nuclearcobra January 15th 2012, 6:08 pm
Most heads have that not a problem as stated.
nuclearcobra
nuclearcobra
Post  bbf-falcon January 15th 2012, 7:46 pm
Is that goin in the Comet Dave?
Post  dave d January 15th 2012, 8:06 pm
yea hopefully make it a lot quicker Very Happy should going from a 429 to 545
dave d
dave d
Post  c.evans January 15th 2012, 10:08 pm
Make sure that you use Loc-Tite or some kind of thread sealant, because it will suck oil through each of those holes if you don't use anything at all.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  dave d January 16th 2012, 9:09 am
Thanks everyone for the input
dave d
dave d
