Shim stock
Shim stock
Guy's how many of you have ever used shim stock for checking clearence's. And where can you get it. I just installed a checked the clearance of my rods after ordering a .001 extra and it went from .0015 to .0020. I still think this is a little on the tight side. So a firend started talking about shim stock is how he does it. But he's 80 miles away to borrow his stuff.
Ace
Ace
Last edited by powerstrokeace on January 28th 2012, 8:09 pm; edited 1 time in total
powerstrokeace- Posts : 1496
Re: Shim stock
If you don't have the right tools,you can take it down to the machine shop and have him to mic the journals and the rods.
Re: Shim stock
Cranks in the block allready and I have zero time during the day to due this. No machine shops are open on weekend as well. Ijust don't trust the plasti-gage deal 100%
Ace
Ace
Re: Shim stock
Plastagage is just to give you a ball park figure imo. I used it successfully years ago before I bought the necessary tools to do it the right way.
If you can mic the crank rod journals, mark them down and maybe you can have someone to check the rods.
» shim kit
» Need a Flexplate Shim-.090
» Starter shim or weak battery?
» Waking up a stock 5.0 roller engine - valvespring options while keeping stock retainers/rotators, etc...?
» Mercruiser Shim Head Gasket OK for Budget Street Use?
