466 shortblock f/s
466 shortblock f/s Empty 466 shortblock f/s
Post  KY JELLY September 19th 2009, 7:15 pm
Weisco dome pistons
eagle srp rods
lunati 272/280 700 solid roller cam
comp solid roller lifters
oem crank / .030 over block
frpp timing gear set
Kaase oil pump
Canton full box oil pan
assembled
$2,800
KY JELLY
KY JELLY
466 shortblock f/s Empty Re: 466 shortblock f/s
Post  sg86coupe September 20th 2009, 9:44 am
more info. How many runs on motor, what heads were on it, how fast did it go, does it need freshened up, any damage?
sg86coupe
Post  KY JELLY September 20th 2009, 10:15 am
It has about 75 runs on it since it was freshened up. It ran A 5.51 @ 124 1/8 mile with TFS street heads ported by Charlie Evans in a 2367 lb mustang . The only damage is the oil pan was patched from a kicked out rod from a previous owner. This engine was originally built by the Evans boys and I bought the short block from them and installed my cam. I actually won the 08 bbf bash with this engine . Several guys on here have seen it run. It is commonly known as "the school bus motor"
KY JELLY
KY JELLY
Post  Nevs September 20th 2009, 5:13 pm
KY JELLY wrote:It has about 75 runs on it since it was freshened up. It ran A 5.51 @ 124 1/8 mile with TFS street heads ported by Charlie Evans in a 2367 lb mustang . The only damage is the oil pan was patched from a kicked out rod from a previous owner. This engine was originally built by the Evans boys and I bought the short block from them and installed my cam. I actually won the 08 bbf bash with this engine . Several guys on here have seen it run. It is commonly known as "the school bus motor"
And it's one "bad" 466" Exclamation Runs way better than it should for it's size Exclamation Nice piece, good luck with the sale, Randy. Cool
