Solid flat tappet limitations
mudtrucker
Solid flat tappet limitations Empty Solid flat tappet limitations
Post  mudtrucker February 7th 2012, 8:57 am
In general how much lift can you have with a solid flat tappet cam without going to extreme duration?
mudtrucker
mudtrucker
Solid flat tappet limitations Empty Re: Solid flat tappet limitations
Post  rmcomprandy February 7th 2012, 12:07 pm
mudtrucker wrote:In general how much lift can you have with a solid flat tappet cam without going to extreme duration?
You better define EXTREME duration.
Max lift and flank velocity are the limitations of a flat tappet lobe given the diameter of the lifter.
The limitations of a roller lobe are it's maximum acceleration and minimum intensity which can be achieved; again given the diameter of the lifter wheel.
Post  IDT-572 February 7th 2012, 5:13 pm
There are plenty of flat tappet deals out there that will smoke what the majority of use run in our rollers.
But it's all about application and practicality.
1.125 face carbon steel mushroom lifter and A 8620 bull nose core. High dollar Twisted Evil
ctdck likes this post
Solid flat tappet limitations Empty SOLID LIFTER LIMITS
Post  RACER RED February 19th 2012, 10:55 pm
IDT 572, You mentioned the mushroom lifters and bull nose cam, where can you buy these items and what are you calling pricey? Thanks for help. Dave Very Happy
RACER RED
Post  dfree383 February 20th 2012, 12:13 am
RACER RED wrote:IDT 572, You mentioned the mushroom lifters and bull nose cam, where can you buy these items and what are you calling pricey? Thanks for help. Dave Very Happy
They will cost more than a typical roller set-up...... I haven't seen any mushroom lifters for a long time but the custom cam cores can start at about $500-800+ depending on how many you want and if they are common or not.
Edit..... http://www.schubeckracing.com/mushroomlifters.html About $1200 for mushrooms ($600 for 8ea x 2) + machining of the block to fit them.
Solid flat tappet limitations Empty SOLID LIMITS
Post  RACER RED February 20th 2012, 11:21 pm
dfree383,Thanks for the response. Well that certainly is a bit pricey,especaily with the extra machineing invovled. Certainly not a cost effective approach the getting more lift under the curve. I dont want to run solid rollers on the street but want to get as much lift as possible to feed a big cu in motor.Thanks again. Very Happy
RACER RED
Post  rmcomprandy February 21st 2012, 12:36 pm
RACER RED wrote:dfree383,Thanks for the response. Well that certainly is a bit pricey,especaily with the extra machineing invovled. Certainly not a cost effective approach the getting more lift under the curve. I dont want to run solid rollers on the street but want to get as much lift as possible to feed a big cu in motor.Thanks again. Very Happy
Those who are required to run flat tappet lifters because of rules get the lift they want by juggling the rocker arm ratios.
I ran mushroom tappets for years in Big Block drag race Mopars and there were no SPECIAL camshaft cores, (I believe the Chrysler "MINI EXPRESS" camshaft is still sold from the Mopar catalog), or extra machining to be done other than a bit of hand grinding on the block bulkheads near the lifter bores.
We ran them in small block Chevy short oval track engines for years also. The cores were regular cores but, the lobes were narrower and ground between them.
Post  mudtrucker February 21st 2012, 1:08 pm
Like always I did not word my question properly and kinda got flamed and then it goes to hell talking about mushroom lifters that would cost three times as much as a roller lifter. I was simply asking how much lift can you get by with out going over say 270-275 @ .050 on a standard solid flat tappet. When does the ramp rate become to extreme for a solid flat tappet? I am looking to run a solid flat tappet in the .700ish range with around a 270-275 dur@.050,Flame away!!!!!!!
mudtrucker
mudtrucker
Post  IDT-572 February 21st 2012, 1:22 pm
.398 with a 1.8 rocker .716 before lash 270-275 @ .050 Comp has several lobes in this range and about 184 @ .200 low 300's @ .020 There are more aggressive but I normally stay around this for reliability.
I would run the EDM lifters with this lobe. And Higher spring pressures are required.
This is what I put in Mike Jaworskie's 528 in the build section, It made good power for a flat top flat tappet deal.
Hope this helps Sorry if you thought I was flaming you.............
Post  rmcomprandy February 21st 2012, 6:21 pm
mudtrucker wrote:Like always I did not word my question properly and kinda got flamed and then it goes to hell talking about mushroom lifters that would cost three times as much as a roller lifter. I was simply asking how much lift can you get by with out going over say 270-275 @ .050 on a standard solid flat tappet. When does the ramp rate become to extreme for a solid flat tappet? I am looking to run a solid flat tappet in the .700ish range with around a 270-275 dur@.050,Flame away!!!!!!!
That's the main reason I said to explain your meaning of EXTREME duration.
That term would not be near the same for everyone.
Snake is correct ... about .400" lobe lift at 270/275 @.050' duration with a Ford .875" lobe profile; (a bit higher with more ramp aggression).
Post  IDT-572 February 21st 2012, 6:40 pm
Thanks Randy............. Wink
Post  richter69 February 21st 2012, 7:55 pm
the Snake is a flamer????? Razz
