528 BBF $4750
528 BBF $4750
528 cube
stock block d1ve stort filled with hard block
scat 4.300 stroke cast crank
Eagle h beam rods 6.8 long
ross custom pistons 10.85:1
Main girdle
Fox body moroso pan
double roller timing set
herbert solid roller 261, 270 @ .05. .710, .714 lift
comp roller lifters
Ported dove heads 2.19, 1.76 valves
ported victor 4500
msd pro billet dist.
ATI super damper
Runs 6.20's in 3280 pound fox body with 1.37 60'. With 1150 dom. and Hooker 2" swap headers(also available). 60 passes on assy at the most. Engine was built by my brother who is an employee at BES racing engines. This is a good low maint. engine. PM or call me with questions. Derek Angne 513-476-6905, bbf528stang@yahoo.com. I am located in Hamilton ohio 45011.
PRICE REDUCED $4750 Intake to Oil pan
Main girdle
Fox body moroso pan
comp roller lifters
ported victor 4500
ATI super damper
derek528- Posts : 115
Re: 528 BBF $4750
how long ago was this engine last gone threw? what is the oil pressure when its hot?
ever had any problems?
racinghabbit- Posts : 575
Re: 528 BBF $4750
Dustin,
The engine was assembled in 2007. I never had any problems with it. Only pressure has never been an issue. I can't remember exactly what it is, it's around 30 psi at idle and 65-70 psi at 6000 rpm.
Derek
Derek
Re: 528 BBF $4750
what is the most common rpms it peaked at?
Re: 528 BBF $4750
generally I left the starting line at 4000 rpm, shifted at 5500 rpm and went through the traps at around 6000 rpm.
Re: 528 BBF $4750
newbie here. Are these iron heads? CJ scj? Etc. More info thanks I got a 86 foxderek528 wrote:price lowered
2fox- Posts : 275
