new guy 429 in 89 coupe
new guy 429 in 89 coupe Empty new guy 429 in 89 coupe
Post  7ohhhh February 12th 2012, 4:37 pm
hello all just got my motor and trans it. seems like that is the easy part. now to hook everything up. i installed the manual brake master cyl. the oem one had 3 lines the new one has 2. am i supposed to block one on the proportioning block? a little insight would be helpful. also does anyone have a part number for radiator hoses?
7ohhhh
new guy 429 in 89 coupe Empty Re: new guy 429 in 89 coupe
Post  Mark Miller February 14th 2012, 12:10 am
You could block one port off or just use another proportioning valve.I used radiator hoses for a mid 70's Lincoln with a 460 and trimmed them to the size i needed.
Later Mark.
Post  7ohhhh February 18th 2012, 5:51 pm
thanks for the advice. any ideas on a trans mount. i have the adjustable crossmember and a c6
7ohhhh
Post  DFI429 February 18th 2012, 9:19 pm
7ohhhh wrote:thanks for the advice. any ideas on a trans mount. i have the adjustable crossmember and a c6
You're already all set. Stock rubber mount (T5) fits the C6, and the adjustable crossmember will allow the adjustability you need. Solid mounts aren't generally recommended due to chassis flex & stress on the C6..
Hope this helps!
DFI429
DFI429
