Cummins 4BT 3.9
Mark Laczo
83-88T-Bird Guy
Cummins 4BT 3.9
any opinions on them? How much do they weigh?
What Transmissions bolt to them?
Re: Cummins 4BT 3.9
Is that the engine that is half 2/3 of the 6 cyl. Cummins in the Dodge trucks?
A month ago the guy that bought one of my T-Birds mentioned someting about the 4 cyl. cummins.
He said they came in bread trucks. Apparently they are pretty good engines.
83-88T-Bird Guy- Posts : 1003
4bt 3.9
Here a link or two,
http://www.4btswaps.com/forum/forum.php
http://www.4btswaps.com/forum/showthread.php?15772-2003-Ford-Expedition
http://www.dieselpowermag.com/tech/0905dp_cummins_diesel_engine_swap/viewall.html
http://www.dieselpowermag.com/features/ford/0808dp_1998_ford_ranger_cummins/viewall.html
Hope this helps.
Hope this helps.
Mark Laczo- Posts : 274
Re: Cummins 4BT 3.9
Mark Laczo wrote:Here a link or two,
Hope this helps.
Thanks for the links !
Re: Cummins 4BT 3.9
They are a super reliable engine.There is a diesel performance shop close to here that has put one in a late model S-10. I saw it the other day pullin a gooseneck trailer and it was the wierdest thing to see.Alan is right,they put them in bread trucks,Doritos trucks and i've seen some in the chevy box trucks.I always wanted to do a 4BT swap in my ranger.---RED
61coon- Posts : 1824
Re: Cummins 4BT 3.9
Here's a short clip of the truck i found...
https://www.youtube.com/watch?v=m3maaWDH6T4
Re: Cummins 4BT 3.9
Amazing little torque-monster diesels. They have a cult following. One place you can look for them is in step vans that have been converted over to those engines, such as the old Kilpatrcik Bread step vans or the Fedex delivery step vans. The reason for this is because as the in-line 6's and small block V8s became worn out in those vans, the quick fix was offered by a company called Repower.dfree383 wrote:any opinions on them? How much do they weigh?
Repower offered the 4BT as a quick swap deal for those step vans. Van himself bought a dead step van that was owned by some big commerical moving company (Global Express?) and rebuilt the 4BT that was in it. Since the step van's original engine was a Ford 300 6 (obvious because of the radiator and the trans adaptor plate), the repower already had a Windsor transmission adaptor plate on it. Van removed the trans that was in the step van and bolted a ZF-5 speed directly to the adaptor plate on the 4BT. Fully loaded with 8 compeltely assembled engines, Van's step van can climb Hwy 405's Sepulveda Grade up and out of the San Fernando valley and over to the Long Beach exporter....without downshifting from OD 5th gear.
Paul
P.s.: The Cummins 4BT debuted at the SEMA show in the 1980's. Van was so interested in going to the SEMA show specifically to look at the new 4BT engine that Chuck Stevens kindly bought Van his show pass.
Paul
Re: Cummins 4BT 3.9
A lot of guys put them in rangers, and F150s I think Fordcummins.com has swap info and kits for them.
Re: Cummins 4BT 3.9
Barney wrote:A lot of guys put them in rangers, and F150s I think Fordcummins.com has swap info and kits for them.
I'm thinking old style Bronco.... Hummmm.......
Re: Cummins 4BT 3.9
Dave,
I don't know if you have it or not but the February 2011 Petersens 4 Wheel & Off-Road is the Magazine you're looking for.Page 68 has a 66 Bronco with the 3.9L Cummins 4BTA Diesel and like Paul Kane mentioned it had a Ford ZF 5 Speed transmission.
Later Mark.
Later Mark.
Mark Miller- Posts : 1946
Re: Cummins 4BT 3.9
Sweet !!
Re: Cummins 4BT 3.9
It's not powered by Ford but still pretty cool!!!!
Later Mark.
Later Mark.
Re: Cummins 4BT 3.9
Mark Miller wrote:It's not powered by Ford but still pretty cool!!!!
Later Mark.
Its OK as long as its not a GM !!!
Re: Cummins 4BT 3.9
Very true better then Generic Motors junk!!!
Later Mark.
Later Mark.
» cummins or 7.3
» Cummins paint gun
» Cummins Dyno Failure
» 2017 6.7 Cummins 4x4 auto
» Cummins 3029514 Turbo
» Cummins paint gun
