BBC Plug Wire Ends
Rvesterby
BBC Plug Wire  Ends Empty BBC Plug Wire Ends
Post  Rvesterby September 20th 2009, 2:07 pm
To lazy to go to Oreilly and find out and never owned one (chevy) so thought I would ask the brain trust.
My BBF has 2 3/8 headers coming straight out from the A Head ports for a good distance - Because of that I can run my plug wires from the distributor down the front of the block and under the headers to the plugs - I presently have 45 degree ends on the wires and because they can attach from beneath it looks like 90 degree ends would work better - so the question is do BBC wires come with 90 degree ends ?? And I assume length wise they would be comprable to a BBF ??
Any body got first hand knowledge ??
Appreciated & Thanks
Ron in Houston
Rvesterby
Rvesterby
BBC Plug Wire  Ends Empty Re: BBC Plug Wire Ends
Post  David Cole September 20th 2009, 3:19 pm
I'm not sure about the BBC ends, but I used 90° boots with my A heads. I used the MSD Universal set # 31229. The plug end comes installed you cut to fit and install the distributor end.
BBC Plug Wire  Ends DSCF0009
BBC Plug Wire  Ends DSCF0012
BBC Plug Wire  Ends Empty thanks
Post  Rvesterby September 20th 2009, 4:17 pm
That is what I want to do - thanks, appreciated
Noticed seperators - are these just on the wires, or attached to the block some how
Looks like they are just free hanging
Rvesterby
Rvesterby
Post  David Cole September 20th 2009, 4:29 pm
I use these:
http://www.summitracing.com/parts/MSD-8843/?image=large
One wire on each side is zip tied to something and it keeps the whole bundle from flopping around. The coil bracket on one side and the braided braided water line on the other. Notice the red zip tie on water line in the first pic just above the front motor plate.
Post  billandlori September 20th 2009, 4:44 pm
I have always like the universal wire sets best, you can route them where you want. I bought a set of FRPP wires for the 460 and they fit good going around the front of engine. They are pre-terminated.
Bill
Post  Doug Rahn September 20th 2009, 6:19 pm
I like the MSD Multi Angle Boots that can be bent to accommodate any application.
Post  mico September 20th 2009, 10:24 pm
I used BBC under header wires from Moroso on my A head engine. All 8 wires work but they are pre numbered so #1 doesnt go to #1 ect. The coil wire is not booted on the coil end for a custom fit.
mico
Post  elimn8u September 24th 2009, 3:43 pm
Rvesterby wrote:To lazy to go to Oreilly and find out and never owned one (chevy) so thought I would ask the brain trust.
Ron in Houston
Ron,
We're a dealer for the FireCore50 line of wires and can get sets custom made for you as well.
https://www.429-460.com/stuff-for-sale-f1/firecore50-ignition-wires-t490.htm?sid=ebce29b6563802f20ff913cadcaed4cd
Let me know if you're interested...damn fine wires!!
Gene
elimn8u
elimn8u
http://www.elimn8u.com
BBC Plug Wire  Ends Empty Some examples.
Post  elimn8u September 24th 2009, 3:51 pm
BBC Plug Wire  Ends Firecore50big
BBC Plug Wire  Ends Firecore50sbf
BBC Plug Wire  Ends FCRoth3
BBC Plug Wire  Ends Firecore50-2
BBC Plug Wire  Ends FireCoreCorymac
elimn8u
elimn8u
