Machine shop
Machine shop
What all does a machine shop need to totally race prep a block other than one piston and head studs?
tconnection- Posts : 866
Re: Machine shop
Need all the pistons. Need to know what rings you plan to use. Need to know what height to deck the block to. Steve
466cj- Posts : 391
Re: Machine shop
Plus...
If you want to make sure your main bearing clearances are correct...the first time.... supply your crank and bearings. If the main bores are on the tight side of the tolerance, they may need line honed. It is much better to figure that out prior to assembly time.
Another thought...if it will have an aftermarket stroker assembly, you should validate rod to block clearance.
It is also a great time to check lifter bore clearance, and If the shop will install your cam bearings, they should ask for the cam that will be used.
Just a couple more thoughts.....
Keith
Keith
Re: Machine shop
tconnection wrote:What all does a machine shop need to totally race prep a block other than one piston and head studs?
Enough money to pay for all the hours spent.
Re: Machine shop
rmcomprandy wrote:tconnection wrote:What all does a machine shop need to totally race prep a block other than one piston and head studs?
![What a Face](https://2img.net/i/fa/i/smiles/fresse.png)
D. Sea- Posts : 2768
Re: Machine shop
D. Sea wrote:rmcomprandy wrote:tconnection wrote:What all does a machine shop need to totally race prep a block other than one piston and head studs?
I can't tell you the amount of people who come in here wanting the short block "set-up" for them to assemble and will pay for the machining but, will expect you to spend the hours to do all the fitment work for $150.00 or even less.
![Rolling Eyes](https://2img.net/i/fa/i/smiles/icon_rolleyes.gif)
Re: Machine shop
I hear ya' Randy. Some people want stuff for "Free"
Re: Machine shop
I for sure dont want it done for da low nor for free,. I rather pay the cost for good work. I took it to the machine shop today for a total race prep. Its a new a460 block. He only asked for one piston head studs, rings and support rails for file fitting and is gonna install coated dura bond cam bearing for like 700 bucks. Jus didnt know wat all was needed lastnite.
Re: Machine shop
I was told the block will get bored and honed with torque plates, align hone the mains, decked and coated cam bearings. Why would all 8 pistons be needed?
Re: Machine shop
If they are all exactly the same only need one. Some will marry each to a cylinder if there is a small variation, some just like to check them to be sure none are off so are not get blaimed when the engine has the wrong running clearance on some cylinders because of something not right with the piston.
Steve
Steve
466cj- Posts : 391
Re: Machine shop
What about the piston to wall clearance? Diamond 4.530 piston, would a good shop know what clearance this piston needs? What the best deck height? Domed a460.
Re: Machine shop
466cj wrote:If they are all exactly the same only need one. Some will marry each to a cylinder if there is a small variation, some just like to check them to be sure none are off so are not get blaimed when the engine has the wrong running clearance on some cylinders because of something not right with the piston.
Steve
Just a simple question ... how would you hand fit the rings without having the entire set ...?
Re: Machine shop
rmcomprandy wrote:466cj wrote:If they are all exactly the same only need one. Some will marry each to a cylinder if there is a small variation, some just like to check them to be sure none are off so are not get blaimed when the engine has the wrong running clearance on some cylinders because of something not right with the piston.
Steve
Randy my reply was to the question of why would they need all 8 pistons. As for rings based on the Op's question shop is only prepping the block so will be up to who ever puts this thing together to check everything is right and to clearance the rings, etc...
Personally IMO he'd be better off to have the shop do the short block! Everyone wants to put it together, but most don't have the measurement equipment and knowledge to do it right. When I used to work at a machine shop we would ask for everything and check the bearing clearances to the crank and cam, fit the rings, do all the measurement and prep to make sure everything was right, then hand it all back to the customer so they could have the thrill of assembly. Really be easier if they just let us do it! Of course some customers do let you assemble it...
Steve
466cj- Posts : 391
» Machine shop recommendation
» Machine shop ?
» I need a machine shop recomendation
» Bad news from the machine shop
» Machine shop near Norfolk, Va
» Machine shop ?
