How big can you go?
papamoe
How big can you go? Empty How big can you go?
Post  papamoe March 2nd 2012, 7:31 pm
How radical can you get with the cam profile on a tfs A460 headed engine? Where do the problems start?
papamoe
How big can you go? Empty Re: How big can you go?
Post  rmcomprandy March 2nd 2012, 7:49 pm
papamoe wrote: How radical can you get with the cam profile on a tfs A460 headed engine? Where do the problems start?
Somewhere just under .860" valve lift unless you use different valve springs.
Post  papamoe March 2nd 2012, 8:08 pm
I rfigured on the springs. I currently run just over .800 and was looking to make a change maybe make more hp up high.Just dont know the right combo.
papamoe
Post  cool40 March 2nd 2012, 8:24 pm
whats the cam now?
Post  papamoe March 3rd 2012, 7:24 pm
The cam is 277I 298E @ 50,814I /780E lift,set at 112 deg with 112 lobe sep.
papamoe
Post  Barney March 3rd 2012, 7:53 pm
What do the heads flow, and where? Think big.
Barney
Barney
Post  cool40 March 3rd 2012, 10:38 pm
papamoe wrote:The cam is 277I 298E @ 50,814I /780E lift,set at 112 deg with 112 lobe sep.
more @.050 on the intake to start. Suspect
Post  papamoe March 4th 2012, 12:01 am
The heads flowed 408 @ .8,419 @ .850. I have the heads off now and am hoping to improve them.My man has sf600 bench and know how but is not familar with the head.
papamoe
Post  Barney March 4th 2012, 12:15 am
I would have lift in excess of .850 then for sure.
Barney
Barney
Post  dfree383 March 4th 2012, 12:18 am
I'd get the heads ported by someone who knows A460 heads, the newer TFS stuff will approach or exceed the 500 mark in the right hands. Thats alot more power than just giving it some more lift.
Post  cool40 March 4th 2012, 12:20 am
Barney wrote:I would have lift in excess of .850 then for sure.
with a 800 shot or without? confused
Post  Barney March 4th 2012, 12:22 am
Preferrably with.
Barney
Barney
Post  papamoe March 4th 2012, 8:55 pm
Is anyone able to tell me where to look for gains on the tfs a460 or is that sacred got to kill you if i tell you info? They are 340cc castings.
papamoe
Post  derek528 March 4th 2012, 9:29 pm
papamoe wrote:Is anyone able to tell me where to look for gains on the tfs a460 or is that sacred got to kill you if i tell you info? They are 340cc castings.
Would you be interested in a good CNC job?
derek528
Post  papamoe March 4th 2012, 9:47 pm
I might later but I would like to make gains here at home and kinda learn a little doing so.When I fork the dough out for some cnc ones Im just going to get a new set. Probably sounds a little silly because I know the quickest easiest way to go would be to sent them out for cnc.
papamoe
Post  derek528 March 4th 2012, 9:56 pm
papamoe wrote: I might later but I would like to make gains here at home and kinda learn a little doing so.When I fork the dough out for some cnc ones Im just going to get a new set. Probably sounds a little silly because I know the quickest easiest way to go would be to sent them out for cnc.
Nothin wrong with that.
derek528
