want to build a 557 ?
want to build a 557 ? Empty want to build a 557 ?
Post  2fox Sat 3 Mar 2012 - 9:18
If I do this I
want a pump gas engine what's the Max. Compression a can go with 93.
will have alum heads not sure which ones yet.I want a maintenance free Eng. Not sure on can yet thinking hydraulic roller. Goal is to run 10.00 index with all motor in a 86 mustang LX tubed.9inrear with 4.30's with 31x13 slicks
is this possible? Thanks
gave me a build up list ...on a buget
too don't want a.10k motor
2fox
want to build a 557 ? Empty Re: want to build a 557 ?
Post  schmitty Sat 3 Mar 2012 - 22:23
The $10k budget will be stretched pretty hard depending on how much you already have. By the time you do proper block machining, and buy the stroker kit, there will be about half that in the shortblock with all supplementals. A flat tappet cam will save you about $500 or so. The top end with aluminum heads if you have them ported, intake, carb, and all of the extras will use up the rest of that budget pretty quick. I did a 552 a few years back, with used iron heads, and several other used items and I was pretty close to that budget. Cool
Post  dfree383 Sun 4 Mar 2012 - 1:21
10.5: is a safe number for typical pump gas build, but sometimes you can go higher depending on the combo and how you build it.
PS no motor is maintence free.......
Post  2fox Sat 10 Mar 2012 - 1:50
Maintenance free I.meant hyd roller cam.
I I did some figures
stock.460 core block 300
rotation assy. seen for 1600 that might come with balance.and flywheel balanced too?
m/shop bore hone deck 350
money will be in the heads 2400 right?
plus everything. Else you know I am talking about.
can littered oil pump.pan haedders for fox body t/chain valve covers intake Carb.dist.
sure I left something out bit looks like 10g right oh and pushrods and roller.rockers
P51
heads are good out the box?
can it be done for 7or8k?
thanks if not going to have to go with my 408w
2fox
Post  dfree383 Sat 10 Mar 2012 - 5:51
if you already have the 408 use it....... Your not going to build something new for less than what you already have !!!
If your starting from scratch its a different story.
Post  Onequickfiveoh Sun 11 Mar 2012 - 2:04
So far I've got 50$ in cast stroker crank(used buddy deal) 300 in scat rods, 550 in probe pistons, 150 in machining, 300 balancing rotating assembly and turning crank, 1600 alum scj heads, 115 in solidroller lifters(used) 300 in coated and ported Vic 460 intake, I plan on having around 4500 maybe in my long block.
Onequickfiveoh
Onequickfiveoh
