BBF 460
BBF 460 Empty BBF 460
Post  tbyrd92 March 7th 2012, 5:54 pm
I have a 86 notch back mustang. I want to put a 460 BB in the car. My parts are a stock crank, stock rods and hyperutectic pistons with 10.5 to 1 compression. I have a victor intake going on the the motor, also a voo doo solid roller cam with dove heads with 3.73 gears. Will a 150 shot
be to much for this combination of parts. Also how hard will it be to put this engine in my car? What all will I have to do. I have a short tail shaft c6 going in the car with a 35-3800 stall. Will the drive shaft have to be cut? Thanks for the info guys and gals
tbyrd92
BBF 460 Empty Re: BBF 460
Post  bruno March 7th 2012, 6:21 pm
first off welcome to the site ....
is this engine built ? or these parts what you have already ? ...as far as the 150 shot maybe start out smaller and keep an eye on the plugs
http://WWW.CKRME.COM
Post  quick 52 March 7th 2012, 7:01 pm
i'm running stock rods and kb hyper with spray the most ive done is 150hp without any trouble i here you can spray up to 250hp but im staying around 150hp this is the tune given to me at drag week buy Monty Smith 65n 52f 28*total timing #5fp race gas 100+ with # 9 ngk gap at .030 i use autolite but a retracted tip here a tune Monty gave me for pump gas and stock plugs 42n 36n 28 total timing #5fp i use this alot works great about a 1.5 tens slower then the 150hp but no change gas and plugs
quick 52
