Flex plate bolts???
Flex plate bolts??? Empty Flex plate bolts???
Post  racinghabbit March 8th 2012, 9:17 am
when you use a mid plate you get a spacer for the flex plate. Do you still use the stock bolts or do you get longer ones?? I looked on arp and i could only find stock length..
racinghabbit
racinghabbit
Flex plate bolts??? Empty Re: Flex plate bolts???
Post  dfree383 March 8th 2012, 9:20 am
How thicks the mid plate? Could use some for a Manual flywheel.
Post  ITSA 91 March 8th 2012, 6:54 pm
Are you using a spacer betwee the crank and the flexplate?
ITSA 91
Post  racinghabbit March 9th 2012, 12:00 am
really, Yes the spacer is between the crank and the flexplate... Have you ever seen a motor plate?
racinghabbit
racinghabbit
Post  jbozzelle March 9th 2012, 3:59 pm
Does your plate have a starter mount? Or will the starter still mount to the trans? All the setups I've seen mount the starter to the engine side of the plate to keep the flexplate and starter lined up and just use a longer converter pilot and longer converter mounting pads.
Post  Wheelie58 March 10th 2012, 10:44 am
I recently saw an older JW Wheel that had the flywheel spacer described. It is not like the current Wheel and most common flexplates that use the ARP 200-2902 bolt (.680 long).
You can measure your application and either use the ARP 200-2906 (.725 long) .....OR the ARP 200-2802 for stick application which is 1.00 long. Just check for clearance for the bolt to rear of block and main cap....
I hope this helps.
Keith
Wheelie58
Wheelie58
