need some help
Barney
dr's wife racing
need some help
I am working on the 65's front end.It is a strut front end that use's a mustang /capri style strut.The lower contols arms are nice pieces. The problem I have is they have a piece on the outer end,nearest to the wheel.It is like a heim joint end but with no threaded part.Only the bearing portion it is held in place with with a snap ring. I've had no luck finding these I think they are a common piece because I had asome old lower arms from another car and it has the same pieces but they are wore out. Am I calling them the wrong thing ???? any thoughts where I can find them? demensions are center hole is for 1/2 bolt outside of bearing case is 1 1/4 inch It is .625 in thick. Thanks for any help.
Re: need some help
Barney would Bearing end be the right thing to ask for?
Re: need some help
You can ask for that, but I would just explain what you have and maybe email them a picture and that would give them all the info I would think to help you.
Re: need some help
I usually refer to a rod-end/heim joint without the threaded shank as a spherical bearing/spherical bearing joint.
DILLIGASDAVE- Posts : 2262
Re: need some help
are they the same thing as the strange strut setup uses? sounds like it..........
Re: need some help
cool40 wrote:are they the same thing as the strange strut setup uses? sounds like it..........
X2 Spherical Bearing
BigDave65- Posts : 567
Re: need some help
this maybe? http://www.rjracecars.com/Spherical-Bearing-7500-MM-AUR-GE50ET2RS-Prodview.html
Re: need some help
That's not it .It is a full motion ball type end just like a heim joint but has flat machined shoulders and is held in by a snap ring.Some of the high end shocks use this type of bearing only smaller.cool40 wrote:this maybe? http://www.rjracecars.com/Spherical-Bearing-7500-MM-AUR-GE50ET2RS-Prodview.html
auoria bearing has some that I think will work.Ya'll should check that out they have a bearing for anything. I ordered a bearing from speedway that may be the right one so I,m waiting on it to get here if it is not right I will pull the out of the car so I will have it in my hand when I call auoria.I'll photo it and put it up here.
Re: need some help
I had not thought of that .I would rather do it with the right bearing if I can,but that is a option that will work.Barney wrote:Could you modify it to have a nut welded on it then just use a regular joint?
According to the bearing place the right nae is spherical bearing end .
Re: need some help
Best part about Aurora Bearing is that they are 20 minutes from me, hehe
yellowhorse7- Posts : 1382
Re: need some help
I bet they have a impressive stock. You have to order EVERYTHING here.
Re: need some help
I think that spherical bearing in the link might be a low angle unit for their big bore anti-rolls.cool40 wrote:this maybe? http://www.rjracecars.com/Spherical-Bearing-7500-MM-AUR-GE50ET2RS-Prodview.html
I'm guessing your looking for something like one of these off the Aurora site?
Is there a number on the bearing you have?
Re: need some help
Ward I thought that car had the spindle from a 74ish Capri which is not the same as a Mustang ?
jasonf- BBF CONTRIBUTOR
Re: need some help
You are so right.I'm so dumb it it is a wounder I have lived so long.Not sure why I put mustang in there.jasonf wrote:Ward I thought that car had the spindle from a 74ish Capri which is not the same as a Mustang ?
Done anything with the 466 yet? Hope you are happy with it.
Re: need some help
[quote="DILLIGASDAVE"]
Is there a number on the bearing you have?[/qu That is what I'm looking for.There is no # on the bearing.
Re: need some help
call this number . 260 493 3381 . ask for Greg . he manufactures the control arms and has the parts .
BTW , lot call that set up a Mono Ball
DanH- Posts : 1081
Re: need some help
I thought a monoball was what you were left with after a divorce Thanks Dan I will give him a call.
Re: need some help
dr's wife racing wrote:I thought a monoball was what you were left with after a divorce Thanks Dan I will give him a call.
Hahahahahahahahahahahaha. No I haven't done anything yet Ward. it's actually still in the back of my truck because I can't decide which car to put it in.
