I know i had a build around here somwhere....
Page 2 of 2
Page 2 of 2 • 1, 2
Re: I know i had a build around here somwhere....
Dunno, ur still a fatter bastard then me.
Hows the motor assembly going?
kjett- Posts : 1169
Its not, Ive been busy and every time Ive Talked to Critter hes been swamped to, so i dont know how much or if any is getting done right now
Old blue Racin Team- Posts : 1579
I know the feeling. With the kids on Spring Break, I have a whole week of no after school stuff that I can acutally get out and do stuff in daylight hours. Now that the cab and bed are finally completely skinned out. I need to finish pulling all of the wiring out of the cab. It's time for a good pressure wash with soap to clean the body for paint! Should be re-assembling the thing in the next few weeks.
kjett- Posts : 1169
Nice, ive pretty much finished my wiring just gotta run my power from the tailgate shut off switch to the relay and fuse block and thatll be done, then gotta run the new fuel lines and Ill be pretty much waiting on a engine then
Rear end is now setup with the new gears, its put back together and setting on its on tires once again... hope to have enough time after work tomorrow to pull the front end apart
well its not the big engine that is being tinkered on in spare time BUT in effort to make sure the new shifter was setup right along with the fuel system and what not i did pick up a pretty well stock 429 put on a Stealth intake and a 750 vac secondary carb...
here's the first pass it made in 2 years... (keep in mind that i didnt get ahold of a carb that was worth a shit tell about 11am Saturday and it was being teched at the track at 2pm)
First pass
Second pass
First pass
Second pass
What's that leash you were carrying? Afraid you were going to get lost??? As for bolting the carb on last minute, all I hear is excuses excuses. I did the same thing a few weeks ago, putting the truck through tech with a lift plate bolted in place of the carb and still took home 2 trophys.
kjett- Posts : 1169
That 'leash' is required for every truck that goes into the pit, Even the Modified trucks are, when Herby comes down and Runs he gets stuck pulling it to... and your engine you knew something about/was built up this one is a STOCK 429 with D3 heads
Page 2 of 2 • 1, 2
Page 2 of 2
