9" full floater
9" full floater Empty 9" full floater
Post  motorhead March 19th 2012, 10:07 pm
Anyone ever heard of converting a 9" semi floater to a full floater?
motorhead
9" full floater Empty Re: 9" full floater
Post  Diggindeeper March 19th 2012, 10:36 pm
No but I bet it wouldn't be to hard to do with a few tools, skills, and a d60 donor.
Diggindeeper
Diggindeeper
Post  crittersf1 March 20th 2012, 7:57 am
Isn't that pretty much what NASCAR runs?
crittersf1
crittersf1
Post  schmitty March 20th 2012, 8:20 am
I've seen a few done on Jeeps. What application are you looking to do it for?
Post  motorhead March 20th 2012, 8:26 pm
On my 77 F-150. I'm going to run 44 " tires and I want to keep the 5.5.5 bolt pattern. It's just a dailey driver, but from what you guys have told me, I at least need a full floater rear end.
motorhead
Post  schmitty March 20th 2012, 9:48 pm
I've got 44's on my mud truck and I don't think you would have any trouble with a regular axle as long as you put in good aftermarket axles. I'm running 40 spline axles in mine and I would think I'm abusing what I have pretty badly and havn't had any issues. I know a couple guys running 35 splines axles with 44's and no issues there either. Cool
Post  kjett March 21st 2012, 9:31 am
The full floater on the rear axles has to do with the full float D70's or newer 10.25/10.5's being slightly stronger than the semi-float versions of those axle. If you are running strictly a mud truck, then the upgraded shafts on a 9" will do you fine. If it's a trail/road truck, then you might be better served to swap to a stonger axle.
kjett
kjett
Post  schmitty March 21st 2012, 1:07 pm
Another option if you have a D60 from a 3/4ton, you can get 5 on 5.5 hubs to put on the D60. Might be cheaper than the conversion for the 9" or aftermarket axles. Cool
