A429 heads and cj stealth intake.
yellowhorse7
FORDMUD
I'm looking to sell heads and intake as a package..
Heads have been heavily milled. .100 maybe more. The triangle gauge on the block side of the head is completely removed.
The intake has been milled .100 on each side.
My block was cut to 10.290 and they lined up good.
I have no flow sheets.
Heads have been ported.
Exhaust floors have been filled with aluminum. And the roofs raised. Exhaust has two bolt patterns. Standard and something like a c-head. Porting broke through to the head bolt passages.
All of the extra work was done nice and professional.
Chambers are between 58-60cc.
Intake valve sitting on the seat is raised above the deck.
Heads come with ferrea 5000 series valves and rocker studs. engine had 60-80 runs int the mud.
One rocker stand broke off and has been repaired. It functions properly.
Heads have serial numbers to be the clippers. I had a tiny comp 270 cam. So, I never had problems.
Heads are in decent shape, They are not fresh off the show room floor.
I can email pictures. All the ones I tried to post here showed up massive.
I'm looking to get 700.00. Could be open to trades, up or down. I just finished my iron head 528, and I'm planning a big A headed engine.
Chad
Chad
FORDMUD- Posts : 290
yellowhorse7- Posts : 1382
Re: A429 heads and cj stealth intake.
You better not show up with alum. heads on that beast.
dr's wife racing wrote:You better not show up with alum. heads on that beast.
Nahhhh. My steel heads will still be there
yellowhorse7 wrote:dr's wife racing wrote:You better not show up with alum. heads on that beast.
LOL on a table at the swap meet
John Myrick- BBF CONTRIBUTOR
Takes a heavy duty table to hold them SOB's up!!John Myrick wrote:yellowhorse7 wrote:dr's wife racing wrote:You better not show up with alum. heads on that beast.
56Tbird- BBF CONTRIBUTOR
» A429 heads, shaft rockers, intake
» A429 heads , Victor intake , 545 rotating SOLD
» FS Weiand Stealth BBF intake
» WEIAND STEALTH INTAKE CJ $175.00 NEW
» Weiand Stealth Intake
