My 533 SCJ by Charlie Evans Racing
+16
Gary Blair
342g
Barney
Tore
Greg-P
66prostreetfairlane
nitrous.f
hdandford
Race Ready Fabrications
Kens429
20 posters
My 533 SCJ by Charlie Evans Racing Empty My 533 SCJ by Charlie Evans Racing
Post  Kens429 March 31st 2012, 3:47 pm
I'm going to replace the trusty Mafia headed 466 in the Falcon with a new 533 SCJ built by Uncle Charlie. Many saw this engine on display at the winter tech seminar. Well we put it on the dyno last Saturday. I was only expecting about 850 hp, due to the small front sump oil pan. We were very pleased with a peak of 888 hp and 716 ft/lbs, and a broad curve. With a better oil pan 900 hp would be a reality. We did not test the new headers Alan built, because they didn't fit the dyno.
Some info on the build:
Block: DOVE-A, SVO 4-bolt mains, filled to wp holes
Crank: 4.3 Scat finished by Adney Brown
Rods: Eagle 6.8 with ARP 2000 bolts
Pistons: JE Flat-tops
Oil pan: Stef's 7-quart front sump
Cam: Lem spec Comp solid roller
Rockers: Ford Motorsport 1.73
Heads: Alum. SCJ by Charlie Evans
Valves: I-2.25 E-1.76
Intake: TFS Mafia by Charlie Evans
Carb: Quick Fuel by Phillip Oakley
Thanks to Charlie Evans, Lem Evans, Phillip Oakley, Mike Phillips, Todd Lawyer, ans Alan Flora.
[img]My 533 SCJ by Charlie Evans Racing Spring2012077[/img]
[img]My 533 SCJ by Charlie Evans Racing Scan0001[/img]
Kens429
Kens429
My 533 SCJ by Charlie Evans Racing Empty Re: My 533 SCJ by Charlie Evans Racing
Post  Nevs March 31st 2012, 4:39 pm
Very nice numbers! Congrats!
Post  Race Ready Fabrications March 31st 2012, 6:59 pm
Nice build and great numbers.
Care to share the flow #'s on the heads??
Post  Kens429 March 31st 2012, 8:26 pm
Thanks, guys. I don't have the flow numbers on the heads, but I know that Charlie said he did a lot of porting. I'm sure he will chime in.
Ken
Kens429
Kens429
Post  Kens429 March 31st 2012, 9:09 pm
Videos!
My 533 SCJ by Charlie Evans Racing Th_Spring2012075
My 533 SCJ by Charlie Evans Racing Th_Spring2012084
Kens429
Kens429
Post  bruno March 31st 2012, 9:16 pm
awesome build ken cheers
http://WWW.CKRME.COM
Post  dfree383 March 31st 2012, 9:18 pm
Saw it in person.... It a nice piece.
Post  hdandford March 31st 2012, 9:55 pm
dfree383 wrote:Saw it in person.... It a nice piece.
I wanted to take it home with me Very Happy
hdandford
Post  Kens429 March 31st 2012, 9:59 pm
Since the car was already running 10.0's with the 466, the 533 demands that I upgrade the rollbar to a cage. Cage was finished this week, and certified to 8.50 today. Now I just have to figure out how to get the car to hook with those little 9" tires! affraid
[img]My 533 SCJ by Charlie Evans Racing DSCN0434[/img]
[img]My 533 SCJ by Charlie Evans Racing DSCN0435[/img]
[img]My 533 SCJ by Charlie Evans Racing DSCN0436[/img]
[img]My 533 SCJ by Charlie Evans Racing DSCN0437[/img]
[img]My 533 SCJ by Charlie Evans Racing DSCN0438[/img]
Kens429
Kens429
Post  nitrous.f March 31st 2012, 11:00 pm
what trans in there? Very Happy
nitrous.f
nitrous.f
Post  66prostreetfairlane April 1st 2012, 4:57 am
very impressive numbers and great build! I'm sure it will be an interesting first few test runs.
66prostreetfairlane
66prostreetfairlane
https://www.reiautomationsquad.com/
Post  Kens429 April 1st 2012, 10:11 am
nitrous.f wrote:what trans in there? Very Happy
That trans is a Jerico DR-4. It's going to it's new owner this week. Putting in a clutchless G-Force GF-5R for this season. The clutchless 5-speed will allow me to use less clutch, which should help keep the tires from spinning as bad on the gear change. Plus, the 5-speed is about a tenth faster!
Ken
Kens429
Kens429
Post  c.evans April 1st 2012, 12:19 pm
There are a couple of corrections guys, let me explain. I believe Mike got tired of typing or something, but in the heading of the dyno sheet there are some misprints/typos.
1. The timing is NOT 32*, but 30*
2. The jets are NOT 90 square, but bigger because we used VP113 racing gas.
3. The high speed isn't 35, I don't know what it is, because that's Phillip's department.
4. Ignore the A/F ratio numbers. Phillip and I dynoed Friday and he got the carb squared away then. The header collectors are 4" and then we use a flared adapter piece to go to the 6" flex steel exhaust in the dyno cell. We had the flared adpaters on there when he was tuning the carb. On the last pull Friday it blew one of those off, and that's what Mike was cussing about. So for Sat. we took the other side off and just pulled the 6" flex steel up over the 4" collector. We had a big air gap which as many of you know, fresh air on a wide band O2 sensor gives and erroneous reading.
Hope this helps,
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  c.evans April 1st 2012, 12:27 pm
Race Ready Fabrications wrote:Nice build and great numbers.
Brian,
The SCJ heads have been fully ported/flowed and a larger 2.250" intake valve was put in there. Here are the intake flow numbers. This is the average of all 8 ports.
.100=71.5, .200=155.5, .300=257.3, .400=341.6, .500=393.3, .600=388.1, .700=382.6, .750=380.3 cfm.
Exhaust flow numbers are without a test pipe. Pipe numbers would be about 25 cfm more at the higher flow lifts. The exhaust valve is the FRPP A-429 tulip shaped valve, which is 1.760". Average of all 8 ports.
.100=59, .200=114.4, .300=162.1, .400=200, .500=224.9, .600=240, .700=247, .750=250.5 cfm.
Hope this helps,
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  nitrous.f April 1st 2012, 2:17 pm
Ken
how much was the jerico dr-4 able to handle hp wise? and you understand how to go fast using a stick shift in your car! me to are using a stick behind my bbf, hemi doug nash 5 speed! Cool
nitrous.f
nitrous.f
Post  Kens429 April 1st 2012, 7:17 pm
Ken
I'm guessing that the 466 was making around 700 hp based on a 134+ mph trap speed at 3800 lbs. The only part I broke was a counter shaft cluster gear(old age). I did bend a shift fork and wore down the dog rings and sliders(which is expected). A soft base pressure was essential. It leaves like an automatic...well sort of. Laughing
My 533 SCJ by Charlie Evans Racing Th_20110917183830
Kens429
Kens429
Post  Greg-P April 1st 2012, 8:29 pm
Crying or Very sad That poor Jerico. Sad Put this number in your phone because your gonna haft to step it up http://jeffcoperformance.com/About_JEFFco_Performance.php
Greg-P
Greg-P
Post  Race Ready Fabrications April 1st 2012, 8:49 pm
Nothing like the sound of a big block and a stick!!!!! Cool
Post  Tore April 2nd 2012, 8:48 am
I don't know if I missed it but what size carb we're you running????
Tore
Tore
Tore
Post  c.evans April 2nd 2012, 9:47 am
Tore,
A 1250 cfm QFX from Phillip Oakley.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  Tore April 2nd 2012, 10:13 am
Thats impressive, Thanks Charlie
Tore
Tore
Tore
Post  Lem Evans April 12th 2012, 7:29 pm
"I was only expecting about 850 hp, due to the small front sump oil pan. We were very pleased with a peak of 888 hp and 716 ft/lbs, and a broad curve. With a better oil pan 900 hp would be a reality."
A better pan and 10"-12" of vacuum would net a very nice HP gain Exclamation
Post  bruno April 12th 2012, 8:38 pm
Lem Evans wrote:"I was only expecting about 850 hp, due to the small front sump oil pan. We were very pleased with a peak of 888 hp and 716 ft/lbs, and a broad curve. With a better oil pan 900 hp would be a reality."
damn fine piece guys cheers
Post  BOSS 429 April 12th 2012, 11:06 pm
the vac pump on it didnt work?
Post  Lem Evans April 13th 2012, 8:24 am
Not very well in my book....if you'll look at the dyno sheet the engine had but 3-1/2" at 7,000 rpm.
