Fox mustang hood clearance
LivermoreDave
Darrin Gorham
Fox mustang hood clearance Empty Fox mustang hood clearance
Post  dfree383 March 31st 2012, 9:56 pm
What intakes clears a stock hood on a fox with 460 ?
What's needed to clear say a victor, rpm or stealth?
Lower engine? Offset rack bushings? Spacers on k member?
Fox mustang hood clearance Empty Re: Fox mustang hood clearance
Post  cletus66 March 31st 2012, 10:08 pm
Torker II with no spacer and 1.5 in K frame spacers clears the stock hood. Till you floor it, and the air cleaner wingnut makes a dent in your new paint job. A chain fixes that. Motor plates would probably eliminate the whole problem. Embarassed
Fox mustang hood clearance 81MustangRacecar058
Fox mustang hood clearance 81MustangRacecar057
Fox mustang hood clearance 81MustangRacecar066
Post  dfree383 March 31st 2012, 11:46 pm
what mounts did you use?
What springs on the front? Did you lower the front suspension?
Post  Darrin Gorham April 1st 2012, 12:36 am
Dave , you have to work with your headers as far as lowering the k member. Most headers are built around the stock k member and cant be lowered.
Darrin Gorham
Post  dfree383 April 1st 2012, 4:16 am
A little Data on a few Common Manifolds
Edelbrock Performer F 3.75 R 4.49 Avg 4.12
Edelbrock Performer RPM F 4.18 R 6.15 Avg 5.48
Edelbrock Torker 2 F 3.50 R 4.25 Avg 3.87
Edelbrock Victor F 6.30 R 6.30 Avg 6.30
Weiand Stealth F 5.25 R 6.75 Avg 6.00
Weiand Tunnel Ram F 9.93 R 10.31 Avg 10.12
Post  cletus66 April 1st 2012, 10:04 am
dfree383 wrote:what mounts did you use?
D-D mounts and shorty headers. I also got a telescoping steering shaft from Maximum Motorsports, along with their caster/camber plates. The springs are what came on the car when I bought it. It has a stock K-frame and control arms, so I wouldn't be surprised if they are stock 4 banger springs. I didn't try to adjust the ride height. It is what it is..... Laughing
Post  LivermoreDave April 1st 2012, 10:20 am
Dave I know you ask of stock hood clearance and one thing comes to mind. Did the year model you question offer a hood scoop or raised hood of sorts? May be far more economical than the alternate route!
Dave.
LivermoreDave
Post  dfree383 April 1st 2012, 10:22 am
No, the 86 models did not have a scoop like the earlier ones.
I'm thinking I may be able to fit a Victor with a 2.5" cowl, rack drop, and kmember spacers.
Post  rmcomprandy April 1st 2012, 11:11 am
dfree383 wrote:No, the 86 models did not have a scoop like the earlier ones.
Machining down the carb pad of a Victor on a forward angle and using a wide thin air cleaner, (like an oval sideways), will barely touch a stock H.O. hood with the k-member spaced down an additional inch. Use a solid motor mount on the left side.
Post  dfree383 April 2nd 2012, 2:54 am
wheres a good source for spacers & hardware for the K member?
Post  dfree383 April 2nd 2012, 2:55 am
Randy how much needs to be machined?
Have you ever Converted a Torker 2 to a Dominator Carb? Is it worth doing?
Post  cletus66 April 2nd 2012, 8:27 am
dfree383 wrote:wheres a good source for spacers & hardware for the K member?
http://bigblockfox.com/
I got these. Scroll down on the left. Fordified Racing K member spacers.
Post  zbob April 2nd 2012, 8:57 am
left over head bolts work good for the spacers....bobn
zbob
Post  rmcomprandy April 2nd 2012, 10:09 am
I believe it is .400" on the front and .050" on the rear.
I have never converted a Torquer II to Dominator. pattern.
Post  83-88T-Bird Guy April 4th 2012, 7:33 am
cletus66 wrote:Torker II with no spacer and 1.5 in K frame spacers clears the stock hood. Till you floor it, and the air cleaner wingnut makes a dent in your new paint job. A chain fixes that. Motor plates would probably eliminate the whole problem. Embarassed
Yep....1 1/2 inch spacers.
That's exactly how I did it.
Torker II intake.
Also had offset rack bushings and custom made solid engine mounts.
Steering rack to Canton oil pan clearance turned out to be 1/16 inch.
I bought aluminum flat stock and made my own spacers and used long grade 8 bolts. (1/2 inch)
Moroso drop base 14 x 3 aircleaner.
Cleared the stock hood blanket on my ol' 91 Coupe.
The Procharger carb bonnet also cleared. cheers
Fox mustang hood clearance DSCF1915
Fox mustang hood clearance PicsNov142010005
83-88T-Bird Guy
83-88T-Bird Guy
Post  rmcomprandy April 4th 2012, 10:02 am
We've made 'em out of thick wall 1" square tubing; (I realize that in these days people just want to buy everything and actually MAKING something is beyond most people).
Post  dfree383 April 4th 2012, 10:09 am
for me its a time thing...... I just don't have time to waste fabricating alot of small stuff when its avaliable commercialy for a modest sum.
You also have to count the time involved when chasing down the materials and hardware..........
If its something that very costly vs the materials and time involded, I'll take a run at doing it myself.
Post  cletus66 April 4th 2012, 2:16 pm
I am incredibly lazy. Laughing
Post  BigBlockRanger April 4th 2012, 2:45 pm
1-1/2" K-member spacers, Victor, drop base air filter under a stock '83 hood & scoop.
Fox mustang hood clearance 76507_462794219484_687514484_5388509_7845293_n
Fox mustang hood clearance 313307_10150346414909485_687514484_7976231_1447897616_n
Fox mustang hood clearance 521839_10150703770144485_687514484_9197649_788519927_n
Post  rmcomprandy April 4th 2012, 6:19 pm
We already had the metal however, it did take us about 2 1/2 hours time to make 'em, Razz
Leftover head and main bolts from different engines are made good use of at one time or another so, we keep 'em all in boxes...
Post  jbozzelle April 5th 2012, 12:02 pm
BigBlockRanger wrote:1-1/2" K-member spacers, Victor, drop base air filter under a stock '83 hood & scoop.
How low are the headers to the ground? Which headers did you use?
Post  rmcomprandy April 5th 2012, 2:22 pm
We used:
SHORTIES from Stan at Ford Powertrain Applications in Puyallup, WA. 1(253)848-9503
This was a fun higher power engine swap, everyday street car ... hence the stock H.O. hood.
Post  jbozzelle April 5th 2012, 5:00 pm
Thanks Randy
I'm looking to swap a BBF into my 78 Futura. It was always a street car and I see no reason to cut it to pieces with a backhalf, etc... It'll be minitubbed with ladder bars, stock style front end, etc.. I would like to keep the air cleaner tucked under the two or so inch tall forward facing Mustang scoops that car on the early 80's Mustangs...
Post  BigBlockRanger April 6th 2012, 12:05 am
Hookers. They are low, but more because I cut 1 full coil off the front springs than anything. The front of the car sits too low in my opinion. It looks good, but it is a major pain in the ass to get a jack under it. The headers drag a tiny bit pulling into my driveway, but I've had worse.
